I charge the battery or not but will not power up.
Comments:
Jun 17, 2008
- the battery holds a charge, the power light comes on and so does the drive light, can hear the CD spin up. No display, no sound. I have tested the harddrive it is fine. the heat sync fan will not stay on. I do not have a voltmeter to check power to the board. I am selling it on ebay for parts since I can not find the heat sync except on a waiting list. I think it is least case the heat sync, worst case the board. Thank you.
I do tech support, I am not half bad at (repaired more than a few) desktop computers but have only a little bit of laptop skils.
-   Did you ever get a fix, i have the same problem in that the computer shows power, no fan, no screen, and the light blinks like it is in sleep mode. running Vista home. thanks
-   bransonCR
Check your battery charger,check your batt,check the out put of your charger to know and to ensure that your charger is working.if its working good,your batt is already busted or a board problem.
Comments:
Nov 28, 2008
- let someonne check the output of your adaptor.if its over coltage,its time for you to buy a new one.
would not hold charge very long. finally it would not start at all. so, i installed a new battery...
(More)
WOULD NOT HOLD CHARGE VERY LONG. FINALLY IT WOULD NOT START AT ALL. SO, I INSTALLED A NEW BATTERY PACK. STILL WON'T START.
