Question about Danby 22 in. DDW396 Free-standing Dishwasher
Danby DDW396W-2 Spray arm won't turn have checked pump, appears to work, spray arm is clean, drain hole clear, lines clear, HELP
  • 1 more comment
  • Anonymous Jun 27, 2008
    same here, help
  • kylekosik Oct 22, 2008
    My spray arm isn't turning either, I'm looking into it. Pump seems to be working correctly.
  • Ackis May 08, 2009
    Same here... =/
I have had a similar problem numerous times, a couple of which required manoeuvreing it into a place I could work on it, and a laborious removal of the covers. Each time, up until this current incident, the solution that worked, at least temporarily, was quite simple. The recurrent problem was at least consistent: every 6-8 months I would find that the pump would work but the spray arm was not moving. The solutions always seemed to be something different: once all I needed to do was to prime the pump, other times it seemed like calcium and lime build-up was clogging up the parts so a little C.L.R. got me on my way.
This most current incident was more baffling, as my standard solutions did not work. However, I think I finally got to the root of the problem.
Look inside the dish compartment, to the right, near the top. There are two little nubby holes. Their function is to allow air to enter/exit either the spray arm pump tubing or the water filling tubing. Remove the one zillion screws from the cover to access the innards. Pull off the tubing and unscrew the washer (it will be tight due to the sealant on it). Upon inspection, I found that the air hole for the spray arm pump was clogged with food residue. A tiny screwdriver will clear things out nicely - you should be able to see through it. If you clear it out a little but, but still can't see through it, then I presume you're just going to have the same problem back again.
It is important that this be clear so that the water can displace the air while filling is occurring and allow for good suction. Actually, it looked like a manufacturing flaw - there was still some residual plastic from the original molding on the inside, and food was getting caught on it.
Good luck.
Posted on May 26, 2009
  • 1 more comment
  • Justine11 Dec 30, 2010
    YOU ROCK! I thought I got a bum-deal on a 2nd hand Danby for $50. The seller said it was near new... looks that way too. Only the sprayer wasn't working. =( Your solution FIXED it! Thank you so very much... my birthday/Christmas present is now running it's first load! WOO!!
  • kea001 Jan 06, 2011
    Rather than go to all the trouble of taking the machine apart, try taking a can of compressed air with an extending pipe up to the 'little nubby holes' and give each a few squirts.
    That's what I did and it solved the problem.
  • deschlong Oct 31, 2014
    Wow, what a blast from the past this is. This dishwasher I talk about finally gave up the ghost around Christmas 2010. I think it flooded the whole top floor of my apartment one final time before I kicked it to the curb. Basically I would need to babysit the thing while it ran so I could catch it in time before it caused a disaster. Well, after a while you get a little lazy and/or begin to trust that it's finally working properly and BAM you're dancing around the kitchen with all the towels you own mopping up dishwasher water at 3am. That said, these things are pretty handy so I picked up another one shortly after. Well I'll be damned if the thing had the same g.d. problem as the first. Poorly engineered I suspect. But there isn't much else on the market for these countertop models. I left that one behind when I moved. It's somebody else's problem now, or more likely in the trash heap with its brother.
On the arm you have 3 port two spray up one left the other right clean out the once that look like a half dome "this is a water port ' it spray's to the back of the washer .. that how it spins .... the other side as it too take a tiny Tiny screw driver an pick out all the food you can get. turn it on let it run use powder dish soap do this a few time then use c l r on a week or two week bases you might have to do this more then once * do not put plates with food on them in your dishwasher* rinse them first or you can call me to fix it. to came to your home $65 + part an labor have a nice day
Posted on Aug 31, 2012
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
Hello, Im trying to diagnose poor cleaning of glasses in the top rack of my Fridigaire FDB751SCB0. everything seems to work fine but while testing I noticed the upper arm isn't spinning. the lower arm...
Hello; first thing to check, which you don't mention, is which side of the glasses aren't coming clean; the outside, which would be caused by the TOP spray not working properly, or the INSIDE, which would be caused by the spray BELOW the top rack not working. The most common problem causing a spray arm not to turn, and/or poor cleaning, is debris blocking some or all of the spray holes in the arm. Best and easiest way to check them is to remove them; they usually are easily removed with a large wing nut or screw in the center. (Don't drop the screw, if you do it will ALWAYS find it's way to the hardest spot to retrieve it from in the whole dishwasher!)
Once you have the spray arm(s) out (this might be a good time to clean them all) you may notice pieces of debris partially protruding from the spray holes. DON'T pull them out; use something to push them back inside the spray arm. Pulling them out can enlarge and mis-shape the spray holes.
Dislodge any pieces inside the arm by firmly rapping it against a firm but padded object, and shake the debris out over the sink, catching it in a paper towel so it won't go down the drain. Be careful, as broken glass is often inside the spray arms, picked off the bottom of the tub and fed through the pump to the sprays.
Once you don't get any rattling inside after several "raps" on the padded object, the arm should be clean.
Cleaning these spray arms periodically is a good idea even before you have trouble.
Hope this helps, and good luck!
Alec
Jun 04, 2011 | Dishwashers
The impellers are not turning. We have checked the drain and it is clear. Water does come in and empties, but does not get sprayed around by the two impeller arms.
Hi lyst_diva,
Firstly clean the spray arms, do this with small ear-buds & toothpicks. Clean the small holes at the edges. Clogged holes can be the reason why the spray arms aren't spinning anymore.
If this is unsuccessful, it could mean a damaged or non-working Circulation pump (Not really an inexpensive part, it might then be worth considering a new Dishwasher if yours is older than 6 years)
Hope this helps :-)
If you found this solution helpful, please vote accordingly :-)
May 11, 2011 | Dishwashers
Top Rack does not clean, Pump was just replaced. No Error codes. Heat is good, house water pressure is good, drain is good. I've cleaned the filter.
You do not say if the drain pump, the main motor, or the entire motor / sump assembly was replaced. If all the holes in the upper spray arms are clear, replace the VIRO motor. It is a small motor next to the main motor, and it switches a water valve to divert water to either the bottom spray arm or the top spray arm, intermittently. (normally about a 2 minute cycle, unless a "top rack only" setting is selected, etc.) The dishwasher has to be removed from the cabinets to replace it.
Jan 25, 2011 | LG Dishwashers
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Danby Countertop Dishwasher Spray Arm not turning
now ya need to find out how the food got by the screen and into the pump motor to get shot into the spray arm
Dec 29, 2007 | Danby 22 in. DDW396 Free-standing...
Danby DDW396 Spray Arm
The spray arm is controlled by the force of the water. There is no motor running the spray arm. If water is not getting to the spray arm, then it won't spin. It may be plugged with detergent etc. Just a note re. detergent. You shouldn't use hard or caked detergents.
Dec 03, 2007 | Danby 22 in. DDW396 Free-standing...
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Danby 22 in. DDW396 Free-standing Dishwasher Logo
601 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
