Question about Homelite Mighty Lite Blowervac
Must ajust carb to a richer setting after warmup, then readjust when cold. Help!
  • 4,350 Answers
What are you trying to do. There is no actual cold setting that a carb would be set to. Cold running is either by choke or bypass enrichment system.
Set the mixture correctly for normal operating temprature, and leave it alone.
Posted on Sep 30, 2010
Tappet setings for mitsibishi l300 4g63 motor
valve clearances sohc 4g63 carb motor both hot and cold
Valve clearance - INLET mm: 0,15 hot
Valve clearance - EXHAUST mm: 0,25 hot
This engine is set hot if you are repairing the engine and have to do this cold
then set to 0.10mm INLET and 0.20mm EXHAUST
Then once hot readjust to specs
Mar 25, 2018 | Cars & Trucks
My dishwasher does not warmup the water
When you make a direct connection, what? You are dealing with water and electricity, do not jeoporadize the integrity of the unit by changing wiring around, this is really bad, how is the unit set up, is it cold water coming in or hot make sure its cold water coming in.
Nov 06, 2012 | Ariston Technologies LL65 Built-in...
I have a 24hp briggs els have to prime carb with gas to start when cold
check the anti back fire valve on the bottom of the carb it might b e stuck partially closed
Apr 10, 2012 | Garden
2004 XLH 883 C SPORTSTER POPING THUR CARB. & PIPES.CARB REBUILT NEW JETS DIDN'T HELP.WHAT NEXT
Usually, if you go up one size on the slow jet and readjust the idle mixture this solves the problem. I think you bike came equipped with a #42 slow jet. Go up to a #45, the next step richer. If you have not drilled and removed the "anti-tamper plug" that covers the idle mixture adjusting screw, do so. Be careful not to damage the screw as they are not available seperately from Harley. This will enrichen the low speed mixture just a bit.
You can also remove the needle from the slide and install a 3 mm flat washer that is about 0.020" thick on the needle to raise it up just a bit to enrichen the midrange just a bit.
Also, check your accelerator pump for proper operation.
Good Luck
Steve
Jul 04, 2010 | 1993 Harley Davidson XLH Sportster 883
2008 1200 custom runs rich on intial start up than has a rough idle . performance is good after warmup can i retune to smooth out the idle when warm .
check the fittings at the cold start lever on the carb,it might need ajusting,if air filter is chocked it will run rough,
Jul 01, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Engine idling rpm is erratic when cold. low power during startup. fuel mixture is very rich.
ajust your mixture screw on your carb turn it in fully then unturn two and half turns that should get your mixture ok you mat need to fine ajust later
Nov 11, 2009 | 1996 Mitsubishi Eclipse
I need to know what to set the carb ajustments at
Turn the idle mixture screw 1 1/2 turns out from being seated. Then with the engine running in gear under a load in the water turn slowly clockwise. When it starts to die then go a half turn counter clockwise. That is your correct fuel mixture and you should readjust it anytime you have a change in altitude.
Sep 29, 2009 | Boating
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Carb settings
Hi Stephen,
Its simple , just remove the air filter clean it and check the spark plug and reset it to its right specs the gap.
Locate the air-mixture screw on the carb and warmup thebike's engine.
Turn the air-mixture screw in tothe last , but very slowly as to not damage it as its very sharp at the end of it, at this point increase the idling a little thn turn the air-mixture screw outwards 1 and a half turns and you will notice the difference in the engine , it may rev a little higher and be stable , here you will have to reduce the idling speed and again try to readjust the air-mixture screw outwards a little or inwards alittle depends how the engine responds.
Hope this will help!
Knight.(Yamaha Seca XJ750A 1981)
Feb 28, 2009 | 2000 kawasaki KDX 125
Homelite Mighty Lite Blowervac Logo
303 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
