Roper washer wont spin most of the time already replaced coupling
  • 122 Answers
You may have a lid switch not making contact everytime, unplug lid switch and jump switch, if can't remember the colors of the wires, just don't try the green with white tracer, that's ground
Posted on Sep 30, 2010
Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Oct 04, 2009 | Roper RAX7244KQ Top Load Washer
Repalced the coupling and now wont drain
sounds like the motor is locking up and tripping the overload....does it take a while before it will start again.then do the same thing and do you hear a faint click right when it stops? i would remove motor and see if the shaft spins freely.it should not be tight.
Jun 06, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer stopped spinning
Your direct drive coupling on the motor is broken and must be replaced.
This video shows the procedure.
Mar 26, 2009 | Roper RAS8244KQ Top Load Washer
Roper washer will not spin
Check the coupling between the motor and gearcase carefully. If it is good, you'll nees to replace the gearcase. Hope this helps!
Feb 01, 2009 | Roper RAS8445KQ Top Load Washer
I OVERLOADED THE WASHER AND NOW IT WILL NOT DRAIN OR SPIN
your washer doesnt have a belt, it is a direct drive with a coupling on the motor, so that is not likely your problem.
i would look to see if the lid switch is broken, when the switch wont work it wont spin or drain. if the coupling is broken it wont agitate or spin, but will drain the water.
just look under the top and see if the switch is just hanging loose. it has 2 screws holding it to the cabinet and a wiring harness that goes to the control panel.
Jan 08, 2009 | Roper RAS8445KQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
My washing machine wont spin
How do you open the top to replace the lid switch?
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper top load leaking from pump.....any solution other then replacing pump?
replace pump it is all spin welded together and not made for repair besides you already have it off $45-50 will finish repair normally costing 150-200 for tech to do
Aug 06, 2008 | Roper RAS6233KQ Top Load Washer
Roper Washer RTW4300SQ
if the drive coupling is ok then the transmission is the problem verify for sure that the coupling is good
Apr 18, 2008 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
