Question about Mitsubishi WS-55511 55" Rear Projection Television
When my tv powers on, it powers off right away. what causes that
  • 3 Answers
Very probable this is a convergance failure, when the ICs go bad it shorts a fusable resistor to shut down the TV. Very repairable, would recommend having a TV repair facility take care of it, should be able to get it done in your home! Find us, very competitive pricing!!
Posted on Sep 30, 2010
Noisy jumping red pixels in the upper right corner
You are right, this is caused by a faulty power supply that gives you bad voltages. So it can get worse in time.
Oct 10, 2014 | Samsung PN50B860 Plasma TV
When i unplogue the tv or when the electrecity go off my tv can take to 48hrs to restart what ca we do to restart the tv right away.thx
The problem lies in the power supply section. Most probably some electrolytic capacitors are responsible this. Consult someone qualified to fix it.
Dec 23, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My hitachi 1999 tv turns on but off right away has flashing green lights in back
If the flashing green lights are on the circuit board each is tied to a voltage from the power supply----likely damage is there but a 99 may not be economical to fix in 2012.
Nov 04, 2012 | Hitachi Televison & Video
Hi.i have a problem with my tv.the picture is not visible but the picture has come closer means it has a white is in the middle in that line only the picture is coming but how to see it is a thin vertical...
a defective horizontal stage could caused this type of defect,or the deflection yoke is defective and should be fixed right away..have a qualified tech check the tv right away.dont use the tv
Jul 17, 2011 | Televison & Video
I turn the Tv on...it makes a sound like a short and shuts off right away...I pulled the Tv out and looked at the back...turned the tv on again and in the left corner of the TV I saw sparks and the TV shut...
the issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.......
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Yours sincerely.
Elect_Comp.
May 13, 2011 | RCA HD56W66 56" HDTV
I turn my vizio on then it just turns itself off
Tries tv unplug,replug it back like an hour later.By letting the tv resetting itself back to the factory setting.The tv should be working again,if have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish power supply board for the replacememt.
Jan 30, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
I am on Direct TV. That part works fine. The tv however takes several minutes for display to come on.
The tv power supply board is the problems and the causes.U have all the tools and understand basic electronic also can do basic soldering?The power supply board,that the board,where the power a/c cord plug into it.Searches the power supply board for dying and soon to be dead parts call capacitors.These dying capacitors parts are alway bulges or puffing up on it tops.By replacing all these dying capacitors,ur tv will power up right away and have picture quickly,no more taking up times,like several minutes to power up and have picture.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Tv willturn off right after being turned on
this sounds like an IC thats Bad
the time it takes for a bad IC to cause the TV's powers supply to over current and shutdown,,,, sounds like what you are describing..
Aug 11, 2009 | Televison & Video
Sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Nov 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Mitsubishi WS-55511 55" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
