Question about Technics Audio Players & Recorders
THE AMPLIFIER CUTS OFF WHEN I INCREASE THE SOUND.HD560
I've just fixed a Denon amp with the same problem. Replace the mains plug - especially if it a moulded type. Likely that the wires inside the plug have frayed to the extent that there aren't enough strands left to carry the load when the volume is cranked up.
Posted on May 28, 2008
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
Technics HD560 Losing Sound
Hello sir, there are several things you should check for, first the impedance of the amp and speakers, do they match 8ohms to 8ohms, two the amplifiers heat sink is it sufficient? or the amp. may need an extra cooling fan. third the main amplifier is the culprit. check each one and let me know if there is progress. thanks
Jul 18, 2009 | Audio Players & Recorders
Technics amplifier switches off
1-keep good ventillation around and do not block any ventillation holes with any thing.
2-check your connection cable in good condition no touching of inner conductor with any chasis.
3-check your loudspeakers and apply them to the system one by one until you find the bad one(which make the problem if it is bad)
Jul 05, 2009 | Audio Players & Recorders
My pioneer 600w amplifier cuts at high volume...
this means that the enternal preamp is starting to fail eventualy it will make no sound at all if you would like you can use a 4 channel amplifier if you would like to keep this deck
Feb 05, 2009 | Pioneer GM-6300F Car Audio Amplifier
Sound cutting out
Was the amplifier installed by a professional or shadetree installer?
May have tapped into wrong wire for amplifier turn-on.
Jan 02, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp cuts off
The amplifier is going into protection. This may be caused by problems with speakers or wiring, or there may be internal problems in the amplifier. Start by connecting a known good speaker with a few feet of wire, and see if it runs without shutting down. If so, check the wiring and speakers. If the problem continues, the amp should be serviced.
Nov 23, 2008 | Crown XTi 2000 2-Channel Amplifier
Amplifier cuts out sound and then turns back on then couple of more seconds the amp. cuts back out
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Sep 17, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
Sound too low sanyo tv
hi there, amplifier section is your problem, try to test the speakers, test some electronic parts at the amplifier section or see any cold solder at your TV board. ty
Dec 07, 2007 | Sanyo DS31520 31" TV
229 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
