Question about Whirlpool Duet GHW9150P Front Load Washer
Code f 21 is on screen - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 30, 2010
Error code P-21 showing on the screen, printing picking up cyan background. What is reponsible?
Color registration problem is P 21. Need to do a color registration procedure.
May 17, 2016 | Konica Minolta Minolta C224 Copier
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
My washer wont work.its saying f:21
you will need to look in the manual that came with the machine, there should be a list of fault codes in the back, either that or call the manufacturer, they should to answer your questions, you'll find their contact details in the back of the manual
Jan 03, 2013 | Washing Machines
On my onida tv 21's blue screen LOCK CODE PLEASE now tell me the solution?
READ the owner manual for the default code or contact the maker.
Dec 22, 2012 | Televison & Video
95 dodge caravan se code 12 21 55
Well, the code 12 is telling you the battery or the computer has been disconnected in the last 50 starts, code 21 is a problem with the O2 sensor, and code 55 is telling you there are no more trouble codes stored in memory.
Code 21 means the O2 sensor is not switching from rich to lean, which can be a faulty sensor or a fuel problem.
Aug 28, 2012 | Dodge Caravan Cars & Trucks
What is a f-21 error
The Error Code F-21 is a slow or long drain. Most likley cause is a plugged up pump filter screen.
The instructions are located on the following link to clean the pump filter screen.
http://www.fixya.com/support/r4507357-clean_pump_filter_screen_kenmore_he2_not
Apr 15, 2010 | Kenmore HE2 Plus Front Load Washer
I have what appears to be a 21 code
they dont have a 21 error they do have a 12 and a 22 error code. 12 means normal no error detecteced 22 is momentary upset after reset
Aug 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Error Code: E7-21
plaese hepply this problem
Aug 10, 2008 | Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
