Question about Euro-Pro Sewing Machines
Top thread keeps breaking and definately threaded correctly
  • 490 Answers
Either the tension is set way too tight or you have some defective thread.
Posted on Sep 30, 2010
Top thread keeps breaking and I do not think it is a bobbin issue. Thread seems to be getting snagged up in one of the upper threading spots. It has been professionally serviced many times.
Remove the top thread from the machine.
Install a brand new needle and confirm that the needle is correct for the thread and fabric you are sewing.
ALWAYS RAISE the presser foot and rethread from the beginning. Set the top tension to the midway point. Verify the thread path is correct.
When the presser foot is raised, the thread should pull through with very little resistance. Once the presser foot is lowered, the tension is activated and the thread should not pull through.
It could be the thread is catching a notch or groove. I have a machine that the thread has worn a sharp groove in the finish. I covered it with tape. Fixed.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
May 11, 2017 | Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Oct 29, 2016 | Janome Sewing Machines
The thread continues to break
Install a brand new needle--one that matches the type of thread and fabric you are sewing. If the thread is shredding at the needle, then the needle's eye may be too small for the thread.
All About Needles
Avoid using old or bargain bin thread. Try a different type of thread.
Check that the thread is threaded correctly in the machine and that it is not wrapped around the thread spool or a thread guide. Also, set the upper tension to the midway point, ie the tension could be too tight.
Why Does My Top Thread Keep Breaking Sewing Machine
Oct 17, 2016 | Sewing Machines
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Sep 05, 2016 | Kenmore Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
My bobbin and thread are constantly breaking. I have the correct thread to needle, but I don't even get one stitch before both break. Tension is on auto; should it be less or more?
is the needle in the holder the correct way ( groove in the needle facing the thread )
Is the needle eye the correct size for the thread in use
remove it from auto tension setting and adjust it your self
make sure that the top thread is between the tension plates and not around the thread behind the plates
the thread tension is close to correct when you need a bit of a pull to pull it along to the needle
is the method of threading to the needle correct as any areas where the thread reverses direction will cause it to break
what do mean that the bobbin is constantly breaking or is it the bobbin thread that is breaking
have you got the thread down the case slot and under the flat spring correctly
the bobbin has to be inserted into the case in such a manner that when the thread is pulled , it flows down the slot freely as the bobbin turns
if the direction is wrong , the thread has to move across the sharp edge of the slot and will cut easily
Dec 21, 2015 | Brother Sewing Machines
My sewing machine keep sewing a little bit but breaks the thread everytime the bottom thread is at 0 and 1 my top thread is at 2 or 3 and the top thread breaks please tell me what wrong I am new too.
possibly the top thread is being restricted in movement
check that the thread is between the tension plates and not behind it or knotted up in the way it is threaded
pull on the needle thread and it should move with a steady pull not very hard
if it is not moving fairly easily the check how you have the thread installed
also old thread will break easily as the bonding used to keep the strands together breaks down and is difficult for the thread to slide though the needle
another point is the needle to hook timing and the clearance there as well .
if there is a problem there , the hook will split the thread from the needle and break it
if you still have problems , take it to a sewing machine service center ( any one ) and they will advise of the problem and show you how to fix it
Oct 20, 2015 | Sewing Machines
My needle threads keep on breaking, I don't know what to do
  • Check the tension of the upper thread. If it's too tight, the pressure on the thread will cause it to break.
  • Check the thread you are using. If you're using two different kinds (one on top and one in the bobbin) that difference can cause the threads to break.
  • Are you using the proper thread for the job? Using a thin or light thread for sewing heavy fabric can lead to breakage.
  • Are you using the correct needle? Sewing knits with a sharp needle or sewing woven fabrics with a knit or ballpoint needle can also cause the thread to snap.
  • Is your machine threaded correctly? Incorrect threading can be another cause for thread breakage.
I hope this helps.
Mar 04, 2015 | Sewing Machines
My machine keeps breaking the thread
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Mar 02, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
Oct 08, 2012 | Juki Sewing Machines
Sewing Machines Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
