Question about Sony Handycam DCR-SR42 Camcorder
What is the Sony part No. of the flexible ribbon conector between the screen and the camera?.. Are there other equivalent connectors from other sony cameras?
  • Sony Master
  • 17,130 Answers
You can mention the model of the set -- DCR-SR42 to get the strip connection as it is only available from Sony.
Equivalent one if availabe may not last as the original ....but this is a manufacturing fault of Sony to design the strip that moves through the mechanism and fails often.
Posted on Sep 30, 2010
  • Joep Niens Jan 12, 2013
    Hi Donald, I have a broken ribbin connector in my sony dcd-trv210e. I opened the camera and found the ribbon part number: Y-N1U-568-12. Big question now is where can I order this part. I searched the web without success. Can you help. Thanks very Much. Joep
SONY DCR-SR42 LCD problem The LCD display has blacked out. Suspecting flexible connector worn out or loose connection. I called Sony support and they mentioned it would cost $229 (shipping inclusice). Can...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and will require disassembling the camera and LCD assembly to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 17, 2011 | Sony Handycam DCR-SR42 Camcorder
I had my Sony DCR-SR42 connected via USB to my laptop and was deleting video clips as I have done many times before. Midway through, the camcorder seemed to "lock up". Now, I cannot even get my...
Please replace flexible ribbon wire between lcd board and main board of camcorder as discussed in chat session, this will hopefully solve camcorder problem.
Part number of ribbon wire is as follows..
187145711 ... FP-610 FLEXIBLE BOARD
Thanks.
May 16, 2011 | Sony Handycam DCR-SR42 Camcorder
How do I replace the LCD screen on a Sony cybershot dsc S930 camera.
I am not sure about the specific brand. Open the case by removing screws (usually 5-6). The LCD screen is immediately accessible. Lift it carefully and trace the ribbon connector. Lift the small flap in the connector carefully and pull out the ribbon cable. Replace it in the reverse order.
Jan 03, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Dcr-hc32e no picture on side screen, any solutions ?
There is flexible ribbon wired between lcd board and camcorder board, it seems broken so no image on side lcd screen.
Replace flexible ribbon wire by local camera repair shop because camcorder will take apart for that.
Thanks.
Nov 19, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony MHS-CM1 HD AVC Camcorder
Buttons on the touch panel do not work at all. I tried calibrating the screen as the manual suggested but that does not work either.
The most likely cause for this is a damaged or defective flexible ribbon connector between the LCD and the camera body and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
Aug 14, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
How do I repair the lcd screen for my DSC-H9 sony camera that is broken and only shows a black screen with cracks throgh the lcd area
You need a set of philips screw drivers size #0,#00 and #000. Buy parts camera with stuck out lens but good lcd from ebay. Then replace the lcd screen and the led back light assembly connected by flexible circuit and flip up connector.
May 20, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Sony-DCR-21 E61:11 Error
Hi again,
E:61:11 shows that flexible wire of lens assembly is not inserted in camera main board connector properly.
There are two flexible wires from lens assembly in this camcorder, just check them and make sure both are plugged in main board connectors correctly.
This will solve your problem.
Thanks.
May 05, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony DCR-HC18E, the backlight on the LCD screen will not light up, it does record but you can't see what you are recording and can hardly see the on screen function / menus. Pressing the backlit buttons...
If you close lcd screen in its position, do you see image in eye piece (view finder) ?
If yes, then replace flexible ribbon connecting wire between camera board and lcd board to get picture in lcd screen.
Let me know if you need part number of flexible ribbon wire.
Thanks.
Apr 21, 2010 | Sony DCR-HC18E Mini DV Digital Camcorder
Sony DCR-HC42E LCD not working
(this is a copy of my post from another page, but is relevant to this problem) I have opened my camera and found that the flexible circuit/ribbon cable that connects the LCD to the inside of the camera is broken. This is due to poor design, in which the flexible circuit cannot withstand the constant movement of the LCD.
I have managed to buy a new cable from a Sony repair dealer, and will attempt to fit it later on this week.
The part number for the new flexible cable is:
Ref no. 171
1-864-761-11
FP-185 FLEXIBLE BOARD
if you are interested in how I get on with it, you can mail me at jackstar@ntlworld.com
I won't bother trying to complain to Sony directly, because it is quite apparent that they really couldn't give a toss.
I have now successfully repaired my camera with a new flexible circuit/ribbon cable, and have made some quick notes that can be found here:
http://www.rubbishworld.com/open%20camera%20part%201.pdf
and here
http://www.rubbishworld.com/open%20camera%20part%202.pdf
Good luck.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam  DCR-SR42 Camcorder Logo
587 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
