Question about Mitsubishi WS-65313 65" Rear Projection HDTV
When you press the power button, the green light comes on for about 2 seconds then it shuts off. Nothing shows up on the screen when this happens. The tv just turns on then right back off again.
  • 3 Answers
Possible power supply problem, convergance problem or DM module failure. Recommend having a TV repair facility come out to troubleshoot, should be able to fix any of those issues in your home, for a reasonable fee. Good Luck! We're here if you need us!
Posted on Sep 30, 2010
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
My PS3 isn't working. I put in Madden 2011 and it just shows a blue and green light in the front of the console but nothing comes up on my tv screen. What could this issue be?
Your video settings may be scrambled. Have you recently tried using different cables?
Press and hold the power button until the systems shuts off. (wait 2 seconds) Press and hold the power button again until you here 3 beeps. Let go. It should ask you to connect your controller via usb and press the PS button in the middle of your controller. There will be a menu with 6 options. Try 1-5. If you do not see this menu, chances are, your motherboard has gone bad and will need to be sent in for service.
Be sure to try using HDMI cables and AV (component) cables.
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Nothing comes up on screen
hold power button for 6 seconds see if it will boot after that
Jul 15, 2010 | Toshiba Computers & Internet
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
It comes on but I can't get anything on the screen. if I put a game in it gives me the blue and green light but nothing happens
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
