Have a HP C7280 Photosmart all in one for wireless connection with Belkin 54g Router. Finds router and everything works correctly but when the device is active (switched on) it disrupts attempts to access the internet. I have to turn off the 7280 and re-power the router to get access to the Internet but it then disrupts access when switched on. Cannot get a response from HP as yet and have had to connect via USB as a work round which defeats the purpose of its purchase! The device is some 12 feet across the room. I have re-installed it too many times to have to do it again. Is this a channel or signal strength or settings problem?
  • Anonymous Mar 07, 2009
    printer says it is on the network but no documents make it from the laptops to the printer
    Scholar:
  • 187 Answers
You mentioned it's disrupting internet access when turned on. Can you post the results of a ping and tracert (with it connected via ethernet and turned on)? To ping: 1. Start > Run and type: cmd 2. At the prompt, enter the following and press enter (after each line); cd c:\ ping google.co.uk >> ping.txt ping.txt The last line of the above, will open ping.txt in Notepad, for you to post here. To Tracert: 1. Click Start > Run and type: cmd 2. At the prompt, enter the following (again, press enter after each line) cd c:\ tracert google.co.uk >> tracert.txt tracert.txt The last line of the above, will open ping.txt in Notepad, for you to post here.
Posted on May 25, 2008
Does it mean my adapter is bad if it just stays lite up green and doesn't flash to try & connect to the internet? I installed everything correctly but it still isn't working. Any ideas? I have a belkin...
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Jan 28, 2018 | Linksys WRT54GX2 Wireless-G Broadband...
Bad Belkin 54g Connection Problems!
reboot your modem then reboot the router that should fix it
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Computer sees belkin 54g, shows all bars, when
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
Regards!
Jul 10, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
My belkin router wont work :(
If you access your router, look at the wireless settings, you may need to change a setting to allow b + g connections, your laptop may have a 'b' adapter.
Mar 09, 2008 | Belkin (F5D72304F5D7000) Router
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
207 people viewed this question
k24674
jasbo
jasbo
