Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Fresh water is slowly leaking into the washer inside. we can run the wash onthe drain cycle and empty it, but it continues to slowly fill up again. help.....
  • Bosch Master
  • 17,130 Answers
Possible that the waterlevel sensor pressure switch is not working and so unless it contacts the cycle will not proceed according to the program.
So remove and test the pressure switch with a suction or blowing to see the contacts clicking.
If the switch is OK the program controller can be faulty
Posted on Sep 30, 2010
GE profile wpre6150k2wt washer never fills up, water runs in and immediately drains and the cycle never stops. Status timer on front just has spinning lights
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
Jun 13, 2015 | GE Washing Machines
Machine fills, agitator not working, washing machine empties
May 29, 2015 | Washing Machines
Water fills then drains before cycle starts
May 27, 2015 | Washing Machines
Skips wash and rinse cycle
My advice is free because God is so good!
Apr 29, 2015 | Maytag Bravos MTW6600T Top Load Washer
Installed new pump. Now it pumps continuously
U MEAN DRAINS CONTINUALLY?
Apr 14, 2015 | Washing Machines
I have a Daewoo washing machine fully automatic DW-760 MP. I loaded the clothes and started the machine . water started filling but at the same time water keeps on draining due to which the washing cycle...
Mar 31, 2015 | Daewoo Washing Machines
Why does my sears kenmore washer empty the water immediaely after it fills.
Oct 04, 2014 | Sears Kenmore 3.6 cu. ft. Top-Load Washer
When my washer was draining this morning it would not stop or advance to the next cycle. The motor wouldnot turn offuntil I unpluged it. when I plug it back in the motor starts running again and makin
Sep 07, 2014 | Whirlpool Washing Machines
I have an Estate heavy duty top loader that continually fills then drains and constantly runs water never initiating wash cycle
Apr 26, 2014 | Estate Washing Machines
Drain pump won 't stop running
Nov 26, 2012 | LG WM-2277HW Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
103 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
