Question about Apple iMac 17" Desktop
I have an iMac 17" that has just started to have a vertical line - blue in color. How can this be fixed? It's 3 years old and nowhere near a technical support person.
Hi this is a known problem and will terminally get worse with the only solution being to get a new screen being over £300's.
heres someone who could help you http://www.gumtree.com/london/54/66321154.html
Posted on Oct 01, 2010
Colorful vertical lines on 17"
This is typically a bad or loose cable to the monitor inside the computer. While you can open the iMac, Apple doesn't make it easy. It requires special tools, and there is a lot of tape involved. You can go to an Apple store to get it fixed, or to most computer repair places. It will likely cost you a little more than doing it yourself, but if something gets messed up in the process, they will be on the hook for fixing it, while if you did it yourself, now you have two things to repair.
Feb 06, 2011 | Apple iMac 17" Desktop
Shortly after the warranty was up the first vertical yellow line appeared and now, about 1 months later another vertical line appeared. He's not happy to hear it only gets worse and apple won't do anything...
Although its possible for graphics processor failures to cause vertical lines, they more often create horizontal ones. The first culprit to check for a vertical line problem is the LVDS cable, which it turns out is not that expensive a part (not counting all the work there is in getting to it). To verify this, I would gently flex the cable while the iMac is open and operating, and see if the lines get better or worse. It may also be that the cable itself is fine and just a few of the connector pins at either end are intermittent, in which case it just needs reseating.
Oct 18, 2010 | Apple iMac G5 Desktop
A fine vertical blue line running through imac screen
How long is a piece of string? is the kind of question you've asked. I've a sneaking suspicion you'll get sick and tired of it before it finally goes.
Jun 03, 2010 | Apple iMac G5 Desktop
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
Blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
May 27, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
White vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Dec 15, 2008 | Apple iMac G5 Desktop
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Apple iMac 17" Desktop Logo
314 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
