Question about Sylvania G-Netbook
Cannot configure wi-fi - Sylvania G-Netbook
  • 4,281 Answers
First make sure wireless swtich on laptop is turned on . Press Shift Key + F5 key to turn on the wifi. Make sure wireless network driver installed and enable . Make sure in router wireless is on then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 30, 2010
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Tip
How can I permanently delete a Wi-Fi from iPod?
<p>Include network interface, the iPod Touch is equipped with a wireless adapter that allows hardware to join Wi-Fi networks by default, an iPod Touch love all Wi-Fi was never confirmed, this feature saves users the reenter the work of key network authentication and other parameters. However, in some cases, a user can have a Wi-Fi network to remove the memory of the iPod touch - for example, when the network configuration has changed. You can also prevent applications such as Safari Internet access. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that moment, the iPod Touch lost all memory you have connected to that network - past and configuration parameters. <br />
on Jul 21, 2011 | Computers & Internet
Will not open web with wi-fi i turn on wi-fi device turn Wi-Fi back off
I would say that there is an issue with configuration or codes. Try opening the network and sharing centre and run the trouble shooting option.
Dec 11, 2013 | Computers & Internet
My ZTE v9 tablet phone will not connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Dec 02, 2012 | Cell Phones
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Wi-Fi settings configurations
Prob a faulty wi- fi chip of a faulty motherboard..
Jul 18, 2009 | Nintendo Animal Crossing for DS
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
Sylvania G-Netbook Logo
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
