Question about Seagate (ST3808110AS) (ST3808110AS20TPK) 80 GB Hard Drive
R,Sir My Sata HDD Segate is Detecting But When I Want to make Windows Than it Boot Up Slow And When I Want To make Format it on the time of parttitioning than it will stop on ntfs 20% and from there it will not not move forward what is the reason for it and how can i format my hdd i have use dm but no response pls solve my problem and how can i make windows in it pls reply me model no St3808110as and i have another hdd of segate that is not detecting in my Bios And just hang on Startup of Computer Pls reply for these two hdd solution Thanx.......................
4 Suggested Answers
  • 883 Answers
SOURCE: harddisk
try setting the BIOS so that "AUTO DETECT" is set for hard drive or set each setting manually...heads, sectors, landing the hard drive label
Posted on Nov 20, 2007
  • 310 Answers
SOURCE: hard disk is not detecting
hi, you should try downloading this
and booting off the floppy disk it creates will tell you if theres a problem with the drive and will probably fix it for you..
Happy New Year
Posted on Jan 01, 2008
  • 121 Answers
If your u8 has an operating system installed, yes, you can do that.
Be sure to boot the u8 in Safe Mode to copy your files.
I would also recommend checking the copied files for viruses before you use them.
Posted on Oct 08, 2009
Testimonial: "good sound advice"
Screen says reboot and select proper bootdevice
Guessing, but it sounds like your hard drive has been damaged. You may need a new drive, or at least repairs. If you have a "rescue disk", give that a try.
Sep 01, 2015 | eMachines T Computers & Internet
Sata hdd very slow
hard drive maybe slow 5400rpm not 7200 rpm check drive speed on them
Nov 08, 2013 | Intel D101GGC Motherboard
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
While installing the windows xp operating system, the system hungs while installing, i'm using the I845motherboard with 2.40ghz intel-p4,512x2 memory module, 120gn segate sata hdd.
1st u format the c drive or windows drive than install the xp, if in case again the system hungs.insert the xp cd than follow the instructions and format the c drive.
Dec 29, 2008 | AOpen MX4GVR INTEL 845GV Motherboard
Acer laptop is not detecting harddisk
i thought you have SATA interface, in that case your XP will not be able to access your HDD. But now as you told there is no option for SATA means you don't have SATA interface in your motherboard and the problem might be in your HDD.
  1. So, check out your HDD connection from motherboard and try to install again if no luck then do the following step.
  2. If you have important data/files on your HDD make a backup copy. Then make try to delete all partition and make new partition, then proceed further installation OR if you have recovery disk try to use it to recover your system as factory setting.
May 17, 2008 | Acer Aspire 5004WLMi Notebook
Hard disk stops copying
first you scan pendrive with anti virus Soft ware why mens i think virus probalm your pendrive ok check pendrive witch company pendrive sir give me details full ok have a nice day by sir
Mar 14, 2008 | Computers & Internet
Sata DVD Ausus using K8V-MX
TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
Jan 06, 2008 | ASUS K8V-MX Motherboard
Seagate (ST3808110AS) (ST3808110AS20TPK) 80 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
