Question about Labtec Computers & Internet
Drivers for v-uam32 861162-0000 lz54341 on win7
Mustek 1200cp driver for win7
Such is the problem with many products for Win7. But Win7 64 bit seem to accept such drivers.
Nov 30, 2014 | Mustek Plug-n-Scan 1200 CP Flatbed Scanner
I have a "i-nix NWC-15-2L
That means the win7 has already some driver installed in it.. Unistall the driver from win7 and reinstall your webcam driver from the CD which you got with your webcam (check whether its compatible with win7).. Hope this wil solve your problem
May 13, 2011 | Computers & Internet
Not found win7 drivers
If you have surfed the board manufacturers web site and there are no Win7 drivers to support it, then it is not compatible with Win7.
Microsoft however, have generic drivers that may work.
Apr 13, 2011 | Computers & Internet
Not install to windows7
may your win7 is win7 64bit but your camera driver is for win7 32bit, reinstall driver using driver for win7 64 bit
Jan 23, 2011 | A4tech PK-635 Webcam
Can you give me a link to download a driver for Protax DC500t camera that works on windows7? The disk I have only works on windows xp Thanks, Peter
If your Windows7 is x32 version, then your driver should work in it. But if you have x64 version, you'll get some trouble to install driver for XP in Win7 PCs. I've stuck the same problem like you, but my case was modem problem. Programs like game or other application that can be installed in XP usually can be installed in Win7 64 bit and extracted in Program Files (x86), but driver case is an exception.
I've search via google but I got nothing. Actually, there is a way to install XP driver in Win7 which is use XP Mode in Win7, but you must upgrade your OS to Win7 Ultimate (I think, see microsoft website to make sure) so you can use this mode.
or
you can install two OS in your PC, Win7 and Win XP maybe. When you want to install driver for XP or if you want to do some work related to this driver, you can start up with XP OS, but if you want to do other work, use Win7.
This is so unconvenient, but better than you can't connect your camera to your PC.
Good luck Peter !
Hope this help and be kind to rate my answer please.
(^_^)
Jan 06, 2011 | Cameras
I have installed a windows 7 ultimate after uninstalling windows xp but now my blue tooth device is not working with my laptop it was working earllier with windows xp
no driver detected by Win7 for BT.....all drivers are not provided by Win7...u may not find a driver for your BT to work on Win7, but can try using the XP driver....
suggest have a dual boot....like i use....
WinXP on C
Win7 on D
and choose OS on boot...
so have the advantage of both OS....
Oct 30, 2010 | Computers & Internet
HP TX1110us, custom install to win7, RC inoperable
To get the remote to work on Win7 you need to install the CIR driver. Check the driver download page for your product for the appropriate Win7 driver. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-75405-1&jumpid=reg_R1002_USEN If a Win7 driver is not available then the Vista driver will also work. Please check with this?Plz vote if this resolves issue.. Dreamkam
May 20, 2010 | HP Pavilion tx1000z Notebook
Lan drivers & draphic drivers are not installing. Im using win7
There are no drivers available or needed for this board under Win7.
Optionally you may use this tool (http://www.intel.com/support/motherboards/desktop/detect.htm) to detect any drivers you may be missing. Your biggest problem may be that Win7 hasn't detected your Lan card and update isn't possible. If this is the case try installing a USB Wifi Card and doing the update. Win7 will automatically find the drivers and install them for you with update.
Mar 07, 2010 | Intel D845GVSR Motherboard
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
Feb 01, 2010 | MSI 661FM3-V Motherboard
Computers & Internet Logo
464 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
