How do i wire up my magnavox, home audio theater, mx931 system to my tv, dvd player and vhs player
smeago1
  • 136 Answers
SOURCE: Does not play multichannel audio (5.1) input through optical digital audio
Hi try this.
in the dvd player make sure you just leave it default (bitstream) but in the home theater receiver don't select 5.1 b/c that will only give you a virtual 5.1 not a true 5.1. In fact don't select any sound field at all just select dolby digital or dts depending on the source of the movie then you should be ok.
The only other problem i can see is that hdmi sends both the sound and picture to the tv. You will need to see if there's a function on the dvd player to only send the picture via hdmi and the sound via the optical out of the dvd player.
good luck
smeags.
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
SOURCE: Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
Posted on Jan 22, 2008
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
SOURCE: Oritron DAV 3102 home theater system
I found a website for the remote you need. I need one too. Go to remotes.com and put your model number of DAV 3102 in the space. It will show you the original remote and a replacemet you can use. Kind of expensive but worth it to me.
Posted on Jun 25, 2008
Where to plug in the home theater on the tv?
If you REALLY want to plug your tv into your home theater system there should be rca (red and white) jacks on the back of the tv that say "audio out" or "speaker out" thats your tv's audio output. which is where you would plug in the TV to your home theater system.
But there's really no reason to do this and its not the most desirable way to set u a home theater. Sound doesnt come from your tv, and therefore your tv shouldnt be plugged into speaker (unless you have old school wal cable) sound comes from your cable box, DVD player, VHS, Xbox, Ps3 etc. the sound comes from your source, and these sources should be hooked up directly you your home theater reciever
Oct 01, 2009 | Dynex Televison & Video
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
53 people viewed this question
 Grubhead
Grubhead
