Question about Sony CFD-616 Boombox
Hi my sony CFD-616's CD door won't open. It shows "Err" in the lcd. any thoughts? Thx,
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
falspet
  • 438 Answers
SOURCE: Does not detect CD in drive.
do you have it apart enough to view the CD transport mechanism ? if i so is the CD spinning up ?
over time the laser brightness diminishes and is not eluminating the cd proporly, there is a brightnes controll on the laser assembly, this can be ajuusted to a small degree to restore oporation, mark the original position of the control, the controll is located on a small pcboard where the plug enters the laseser asembely, turn the controll clockwise only about 5 to 10 percent, now atempt to read a good known cd, if it reads, leave it, if not turn the controll counter clock by 5 to 10 persent of the original poition, now try the cd again, if it works leave it, if not the laser may be defective and needs replacing, all this is asuming that the lense is cleen so prior to ajustment cleen the lense, also insure the lense is in place, some lenses have fallen off in my past experiances, and may be rateling around inside the unit, don`t lose it, you can very carefully glue it back in place using crazy glue, the assembely is quite easy to replace, you will see when you have it apart, if you can find a new one for a reasonable price this may be an option for you, one other thing, observer the carage, note if it seems to slide tho the center and then position itself a small portion away from the center this happens only when the unit is trying to read a CD , if so good, if not this may be due to a defective home switch used to position the laser over the appropriate track to read the directory of the CD, you can see the switch, and can be easily replaced, you will know how when you see it, that's what i know so now you know, good luck
Posted on Jan 31, 2010
cyberfast
  • 155 Answers
SOURCE: sony cfd-z110 cd seems to not spin/play when
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Posted on Dec 31, 2010
gopakumarg43
  • 75476 Answers
SOURCE: The Sony CFD 616 is
Hello
Unplug the unit from AC power socket, and remove batteries in the battery compartment if any. After all the indication in the display disappeares insert the power plug and batteries again. If this does not solve the problem of your device, the output IC inside it has damaged and should be replaced with same type and number. OK.
Posted on Jun 18, 2011
gopakumarg43
  • 75476 Answers
SOURCE: CFD-V17 CD SPINDS BUT WON`TPLAY
Check and replace the optical pickup unit. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Posted on Jun 01, 2012
The CD DOOR ON MY SONY CFD 460 WILL NOT OPEN WHEN I PUSH IN THE MARKED LOCATION ON TOP. IS THERE ANOTHER WAY TO OPEN IT?
look for a small hole on the front of the CD tray, about the size of a pencil lead. Straighten a paper clip, and press into the hole to mechanically release the drawer and retrieve your CD.
Feb 25, 2018 | Sony Audio Players & Recorders
Bought a Sony CFD -S70. Worked great, now won’t read a cd. Click it in unit, says “read” and then says “no cd”.?
Chances are there is dirt on the lens of the player. You can get a lens cleaning product from your local hi-fi dealer.
Oct 17, 2017 | Sony Audio Players & Recorders
Need a relacement anntena for sony cfd-s22
Radio Shack is the only store that carries a variety of antenna's, but not sure if they still do.
Apr 12, 2012 | Sony Boom Box With CD Player & Cassette...
My sony CFD-E100 won't recognize CDs
use a cotton swab to clean the optical lens-which is seen by opening the CD cover. if after cleaning the lens it still doesnt play a cd - exercise all manual switches(could be a dirty cd/radio switch), several times. after these steps, and the cd still refuses to spin...its hopless. the optic is bad.and not economical to repair. bet the cotton swab does the trick.
Mar 04, 2010 | Sony CFD-E100 Boombox
Power cord?
Hi
you an buy the item in electrical or electronics store
Thanks!
Mar 10, 2009 | Sony CFD-S250 Radio/Cassette/CD Boombox
Mar 31, 2008 | Sony CFD-S200 Cassette/CD Boombox
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
