Question about Iomega (33090) 250 GB Hard Drive
I backed up my windows XP drive to an Iomega usb drive. I can read the usb drive on that machine and on a Fedora Linux machine, but, NOT on other Windows machines. It won't display the directories/files, yet, if I click on properties it correctly reads the files and reports the correct number of files/size on disk etc. It just won't display them in explorer or the command prompt (yet fedora has no problem reading the files as well as the original PC that I backed up). ???
    President:
  • 2,571 Answers
This is probably due to user restrictions. linux is having no problem, but only the user in windows that created the files can view them.... unless you can change the sharing properties.
right click on the files/folders properties / sharing / advanced sharing, and enable sharing
Posted on Sep 30, 2010
Boot from usb
Introduction UNetbootin allows you to create bootable Live USB drives for Ubuntu, Fedora, and other Linux distributions without burning a CD. It runs on Windows, Linux, and Mac OS X. You can either let UNetbootin download one of the many distributions supported out-of-the-box for you, or supply your own Linux .iso file if you've already downloaded one or your preferred distribution isn't on the list.
Requirements
  • Microsoft Windows 2000/XP/Vista/7, or Linux, or Mac OS X 10.5+. Note that resulting USB drives are bootable only on PCs (not on Macs).
  • Internet access for downloading a distro to install, or a pre-downloaded ISO file
Features UNetbootin can create a bootable Live USB drive, or it can make a "frugal install" on your local hard disk if you don't have a USB drive. It loads distributions either by downloading a ISO (CD image) files for you, or by using an ISO file you've already downloaded.
The current version has built-in support for automatically downloading and loading the following distributions, though installing other distributions is also supported:
Oct 15, 2011 | Microsoft Computers & Internet
How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
I hope this post helps you. I appreciate your vote very much!
Mar 03, 2011 | fedora Linux Operating System
I am having a maxtor One touch 111 external drive which I need to connect to a fedora linux. Do we have a linux driver which can detect the USB drive
If you are just using it as an external drive, Fedora should see the drive automatically, no driver should be necessary. If it can not, there is probably a different issue.
You may need to format the drive if order to mount it.
If it is already formatted as NTFS, it will be read-only to Linux. If formatted at FAT32, Linux should be able to read-write it as well as Windows.
fdisk -l: to get info on all disks (formatted or not) connected to the box. You should be able to figure out which disk is which.
If you will be using this disk exclusively with Linux, you will probably want to consider formatting it with a native Linux file-system.
Nov 30, 2010 | Maxtor OneTouch III 300 GB Hard Drive
Can i use an external hard drive to run an operating system (XP)
Yes. You can run an OS from an external hard drive. You have to install the OS to the External hard drive and will have to boot from the USB. I have tried that for Fedora Linux OS but not for XP. Basically all Operating systems boots up in the same manner. So definitely, its possible with windows XP also.
Thanks
Sherbaz
Sep 21, 2010 | Acer Veriton 5500 PC Desktop
Hello, First of all, I'd like to tell you that I had installed Windows 7 (clean) on my new computer. Then, I installed Fedora 13 64-bit. Eventually, I wanted to install Windows XP, so, formatted the...
Hello there kapeel_sable
First of all, why you want to install WinXP when you already have Win7 and you can just Downgrade it to WinXP..
Best Solution for this is to Recreate partition again. Start it with Win7 (dont worry Win7x is Downgrade-able to WinXP & Upgrade-able to Ultimate, Pro.) Then your Linux box.
Use quicky option compadre...
Hope that helps...
Aug 17, 2010 | Computers & Internet
Windows not booting
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Fedora
When you start your computer Press F2 or F12 to make changes in Boot sequences.Make the CD-ROM or DVD-ROM 1st in the Sequence. Save the Changes and Exit.Before rebooting put the XP CD inside the CD-ROM Drive and reboot.
If you donot have Driver's CD of Motherboard,it is better to make Driver's CD before reinstallation.
Sep 19, 2008 | fedora Linux Operating System
About Linux fedora and XP
Without knowing more about your system, the key rule is to install XP first, then Fedora.
If that doesn't work then it's time to put more partitions on your hard drive, and install the 2 operating systems on different partitions, again, remembering that Windows XP has to be the first installed.
Mar 31, 2008 | Intel D102GGC2 Motherboard
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
63 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
