Replacing an IDE HDD in a XEROX DC 440st
Hi everybody!
I got a trouble with a XEROX DC 440 and i need to replace the image hard disk (HDD IDE) , but i dont have the procedure to do it,,,if someone can give me a hand i will be appreciated.
One original disk is too expensive! mi e-mail is losvi1967@gmail.com Leonel
  • 1 more comment
  • Leonel Sanchez May 26, 2008
    That is not solution,,,there is a solution different,,,a HDD different to original xerox can de work,,,i lost that information because i do it.
  • Leonel Sanchez Jun 26, 2008
    well,,,my problem was solve,,,some one in this forum help me and i am very apppreciated,,,it easy because there is a rutine to recognize the new ide HDD so
    i bought a new hard drive run a rutine y everything was cheap!
  • diebeest Sep 02, 2008
    I too have the same problem replacing the hard disk. I even got exact the same part, all i need to know is what format the disk needs to be reckognized by the printer. I'm trying UFS now.
Congrats you have done great job solving the problem for hard disk error.
Could you please share same to me also?
pmbajracharya@gmail.com
Posted on Jun 28, 2008
    Scholar:
  • 53 Answers
Nasty! If you have the exact Xerox replacement part it's no problem
BUT...we've tried other very similar HDDs (at a fraction of the cost) and had no success at all.We've even taken them to it specialists and they can't make them compatible...Xerox obviously need your money
Posted on May 26, 2008
How do I recover the operating system after replacing a damaged disk?
unfortunately , unless you have the data saved on another hard drive , gig stick etc , it is all lost
you will have to install a new operating system from a cd or download from the net
everything that you view , save on a computer is all on the hard drive initially so when that drive fails --all is lost
there are companies that can remove the disc from a failed hard drive and then recover the data but , the cost has to be considered as it is not cheap
Aug 21, 2017 | Xerox DocuColor 3535 Copier
Hi, can i install a 720 GB internal hard disk for my acer veriton? my present configuration are windows 7 pro,32 bit 160 GB HDD. thanks in advance.
I found a pdf manual here and it shows that this computer does not have SATA ports, but does have 2 IDE ports, so if it's an IDE hard drive you want to install then you should be able to. However, your 2nd IDE port is likely used by a cd/dvd rom drive, so unless you are replacing the hard drive rather than adding one, you would need to remove the disc drive. There are very affordable external usb disc drives available.
Aug 23, 2011 | Acer Veriton 7200D PC Desktop
Xerox Document Center 440 replace cartarage every 4 coppies
just Check The Wiring of dc bord
in back side of a printer.
Dec 28, 2009 | Xerox Document Centre 265ST Printer
Hard drive replacement
Hi there, I have an HP nx6110 and it had a WD 60GB 4200 rpm IDE, I bought a Seagate 80GB IDE Hdd and it worked fine. The only think you should be careful is to check if you need a SATA Hdd or IDE Hdd, but I think it's a SATA.
Apr 02, 2009 | Fujitsu Computers & Internet
Hard Disk Failure
this error comes when the hard disk is not getting detected you need to follow following steps to trouble shoot
  1. check the power to hardisk
  2. check the interface cable ide/sata
  3. replace the cables & check if necessary
  4. check the boot sequence in bios
  5. check if there is a floppy od cd in the drive & remove it
Feb 24, 2009 | Office Equipment & Supplies
Help with Xerox DC 440ST Machine
This problem can only be cured by a Xerox engineer or by someone who has access to a Xerox laptop. You have to have a special program called AltBoot to be able to reload the software.
The only other way is to replace the SCSI hard drive in the ESS (network controller unit) with one that has been pre-programmed.
Sep 10, 2008 | Office Equipment & Supplies
HDD XEROX DC 440 ST
Its only want SKAZI hard disk only
Jul 29, 2008 | Xerox Document Centre 265ST Printer
Installing 2 hard drive
if ur hard drive is IDE port then
attach the 1st end of ide cable to the motherboard and second end of ide cable {IDE1}to the hard disk {make this hard disk MASTER by change the jumper settings }
attach the second hard disk to ide cable {IDE 2} make this hard disk SLAVE by remove the jumper from hdd
Mar 20, 2008 | Computers & Internet
270 people viewed this question
jasbo
jasbo
