Looks like a number of things are happening.
It would be easier if you can provide the model no. of your frigidaire dishwasher.
I am assuming you have turned the mains power off and on.
Hi Thanks for using FixYa. To resolve this press and
hold the AIR DRY or RINSE ONLY button for 15-20 seconds. Please accept the solution if the
issue is resolved or post a comment for further assistance. Thanks Rylee
To start with press -heated dry -high temp wash
and hold the NO HEAT DRY button for 15-20 seconds, if still the issue is not
resolved then check the door switch. If still it's not resolved then do this by closing the door and press these buttons in
sequence...
-high temp wash
mso-bidi-font-family:"Times New Roman";color:black;mso-ansi-language:EN-US;
mso-fareast-language:EN-US;mso-bidi-language:AR-SA">-heated dry
The rinse only button didn't work, I tried it both with the door closed and opened. I also tried holding the cancel button down with the door both closed and opened. I also tried holding both the rinse only only and cancel button down, with the door opened and closed. I did all of this for at least 30 secs. What's another solution?
Is there someone there for a solution??
I do not have a NO HEAT DRY button.. those buttons in numerous types of sequences does not work either.
My only buttons are pots/pans, normal, eco wash, upper rack, rinse only, sanitize, hi temp and heated dry. There is alo a delayed start and start/cancel button.
Is there another solution for me to use Rylee?
hello?
My frigidaire dishwahser was set to run a normal wash cycle and heat dry. It never ran, the soap is still in the holder and the lock beneath the heat dry option is lit. I'm unable to cancel or select any other options. I cannot get the dishwasher to run. Do you have a solution? I have tried holding down a number of the buttons in different combonations but still can't get the light to go out or start a wash cycle. The rinse only button didn't work, I tried it both with the door closed and opened. I also tried holding the cancel button down with the door both closed and opened. I also tried holding both the rinse only only and cancel button down, with the door opened and closed. I did all of this for at least 30 secs. What's another solution?
