Question about Philips 42FD9954 42 in. Plasma HDTV
Phillips Plasma 42" Solid White and Black Line in Picture
I ca use some help if anyone has had this problem, all of a sudden I have a soild white line about 3" wide with a solid black line on the leftside of the white line about 3/4" wide together they make a solid band in the middle of the screen. I have treied to reset unplug turn power off for hours and turn back on, but it is still there. Any Suggestions???
    Brigadier General:
  • 3,614 Answers
Try to check the part on d convergence board.
Thank you
Posted on May 29, 2008
  • micromaster
    micromaster May 29, 2008
    the unit is in fault condition & cannot be restore or repaired it by unplugging only the system... if you have any background doing the repair and replacing and soldering the parts inside maybe you can do it.. but somehow you don't have any idea how to do the job, it is better for to call for a repairman..
    thank you
  • micromaster
    if my info/idea helps you.. kindly please rate my solution..
    ~micro
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Vertical black lines. But they are not solid. lg plasma 42pc3dv
This could be a poor connection with the LVDS cable which runs from the main video processing board to the screen, or a fault within the video processor on the main board. Worst case scenario is it could be a fault with the screen itself.
Jan 08, 2010 | LG 42PC3DV 42 in. Plasma EDTV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel.  Go into your settings and adjust the h/v settings to move the line off the screen.  You can do this with a combination of v-position or vsize.
Jan 26, 2009 | Vizio GV42L 42 in. LCD Television
Solid white horizontal line
ha ha ha ha ha ah ha ah aha aha a a hah
May 04, 2008 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Samsung Plasma lines
Panel could be bad or possibly a cold solder joint on driver ic. Or board that ic is on is bad. Good luck. Jay
Mar 21, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Pioneer PDP-425CMX 42" Plasma Tv
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
Nov 16, 2007 | Pioneer PDP-425CMX 42 in. Plasma...
White line
There are individual drivers for each line of plasma cells in the display (horz. & vert.), but they usually are an integral part of the display module that can only be repaired by the manufacturer. A new 42" HD-ready set with more features can be bought for 50-75% of what was likely paid for this one. The cheapest thing to do is learn to live with it. (That's what I'd do until the set got worse or the prices got even lower.)
Apr 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips 42FD9954 42 in. Plasma HDTV Logo
234 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
