How to fix Toshiba Flash Cards (not responding)
  • tmacgregor Oct 01, 2010
    What a unique and insightful recommendation. DUH!! I am a computer novice, but even I knew to go to Toshiba's website. Had been there, done that. Not helpful. You were less than helpful. $9 ripoff.
  • 5,081 Answers
Flash cards sit at the top of your monitor and add access to function keys
( F1-12) and other functions such as brightness, standby, and some are
programmable.
Go to Toshiba and download and install ALL the new drivers,
BIOS, and utilities...
Posted on Sep 30, 2010
My toshiba flash cards is not responding Can you help
if you are referring to a usb flash drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Oct 17, 2011 | Computers & Internet
Flash cards not responding
That can be a problem with the flash card reader , probably hardware.
Oct 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
I have a toshiba satelite L655, windows 7 home prem(original that came with it). My problem is, i can't see my 'fn' key icons any more. The key works fine apart from the functions that require...
Good day there. I can help you with your concern.
Please follow the steps below.
1.Click Start, All Programs, Toshiba, Utilities, and then click on Restart Flash Cards 2.Click Start, All Programs, Toshiba, Utilities, and then click Settings for Flash Cards 3.A windows will pop up, make sure these two options are checked: "Allow the mouse to bring up the cards" "Keep the cards on top of other windows" Please make sure that these are the only two options that are checked leaving "Disable all function keys" UNCHECKED. 4.Click Open cards case just to check if the flash cards has been reset, you should be able to get a new window. Now close it by clicking on the X button on the upper right hand corner. 5.Going back to Settings for Flash Cards, make sure to click APPLY and then click OK. 6.Kindly test if your flash cards/key icons will appear on top of your screen when using the FN key and also when hovering your mouse on top where the key icons are located.
I hope i have solved your concern for the day. You have good one now. :-)
May 12, 2011 | Computers & Internet
Flash cards are not responding
Take out the flash card and clean the terminals with good eraser then plug it back in and try it. Just make sure you ground your self before touching the flash card. Also make sure not to touch the terminal.
Dec 07, 2008 | Computers & Internet
Toshiba flash cards support utility
i got this problem too , any help
Oct 26, 2008 | Computers & Internet
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Aug 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba flash cards not working ??
It means what it says. There have been mentioned problems of this. You can disable the flash cards (>Start Menu-->All >Programs-->Toshiba-->Utilities-->Settings for >Flash Cards-->Disable Flash Cards) but you then apparently lose the function keys (therefor cannot change the brightness.) First off though you should perhaps state the model of your laptop. If it is the Toshiba A10/700 then I believe there is a Value Added Pack for download on the Toshiba's Canadian website - but has problems. I have also heard of programs causing such problems, such as Photoshop CS2. Is this message appearing after hibernate? If so what programs do you leave running?
Jun 15, 2008 | Toshiba Satellite A135-S4527 Notebook
my Toshiba (Vista home) Laptop flash cards not responding,
May 31, 2008 | Toshiba Margi Compact Flash...
what make and model laptop do you have?
Nov 21, 2007 | Toshiba Margi Compact Flash...
FN keys not working
Search "flash cards" on your computer. Several shortcuts will popup and you shuld see one entitled "restart flash cards". Double-click on this icon and then hold down the fn key to verify if the restart worked.
Nov 03, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
