Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi i have the sony kv32fs120 the tv wont turn on the stand/by timer blinks but no picture tried to unplug for 5 min but it didn't work any advice. thakyou anthony
  • Sony Master
  • 17,130 Answers
Possible failure in the horizontal section of the horizontal driver or the failure of the line output transformer.
You will have to disconnect the +B to confirm if the SMPS gives the power.If so check for short in this section .
respond.
Posted on Sep 30, 2010
  • grajalestr Mar 23, 2011
    you right ..... a vow on you... common trouble in horizontal output
The channel was change and I can't get the channel 3 back. Also, try to problem solved thru the menu botton but it gave me lines I can't do a channel search or stop the lines from going up and down. What can I do. Help
Posted on Oct 07, 2010
NO BRIGHT
Posted on Oct 02, 2010
Hi , i just changed the lamp to my tv and was working fine for 3 to 4 days, but now when i try to turn on the tv- inmediately turns off, and the red light for stand by start blinking, what can i do ,please...
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also did you get the original Philips lamp if you got a generic that
could be your problem.God Bless you!bless!
Dec 16, 2009 | Sony KDS-R50XBR1 50" HDTV
No Picture Stand By Timer Light is blinking
Have to try switching on the the channel through your remote control? Sleep timer maybe On
Mar 01, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Stand by\timer blinks,picture go out everytime it blink .
Blinking codes meaning:
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Good luck:
Dont forget to rate:
Jun 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
65" Sony Sound / No picture 10 & 5 blinks on timer/stand by light
A 10 blink code on this model is usually and ic that has gone out on the d board. If your a novice at tv repair call a service center.
May 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony KV32FS120 32" FLAT TUBE SDTV
Replace Shorted D500 And D503 Sony p/n# 871908100 or NTE571 will work as a good sub. Also Replace Q512 Sony p/n# 872980929 2sc4159.
Parts will be about $17.00 dollars and takes about an hour if you're thinking of taking this to the shop instead...
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
469 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
