Question about Freezers
Freezer quite working after an electrical surge in area...
I have a sister who purchased an 05/2007 Holiday chest freezer, Model #LCH0501PW as of last year. (She resides in Alaska, and has minimal access to qualified help) She purchased this at a local home improvement outlet. There was a minor power surge in her area and her freezer went on the fritz. Could this be a burned motor, or is there the possibility that the unit may have a built-in circuit breaker to prevent this? Seems next to impossible to find a shcematic as this is a very inexpensive model.
  • paulz5 May 26, 2008
    tech17,
    I will be in touch with her via phone, today, and send along the advise you have been so helpful in suppling...hopefully, this may be a possible solution short of having to trash the unit. Can this existing relay possibly be tested with a relatively inexpensive volt-meter?
    Thank you, again!
  • paulz5 May 30, 2008
    Minom,
    Thank you for the advise...I am kind of in the same scenario as yourself, only this is for a little sister that I can"t help directly, as I am in Colorado and she's in Alaska...can only help via advise from my end, though would like to be able to help so much more. Hope that you were able to locate the necessary replacement parts. I encountered the same situation on my end, trying to find parts for the darned thing---wish you better luck, on your search for the parts!!
    Paul
I have this same model. It quit working 18 months after purchase during a house move. It would get cold and then quit with the power light on. I'm replacing the thermostat and the start relay/load protetion parts. That seems to be the problem. $50 total. Finding parts has been nearly impossible as no one recognizes the model # or brand.
Posted on May 28, 2008
    President:
  • 1,314 Answers
Tell her to change the rely on the compressor if there is an appliance parts store tell her to get a three in one reley and follow the instructions that come with it
Posted on May 25, 2008
Is there a reset on a Holiday chest freezer
Check the thermostat, defrost timer and compressor overload one of them could have been damaged by the surge.
Oct 17, 2014 | HOLIDAY 5 cu ft Chest Freezer White...
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
There is frost around the top of my Holiday manual defrost chest freezer freezer - does the seal need to be reparced
if the frost is just around the top seal area then YES.but if the frost goes further down then the whole unit needs a full defrost (NO scrapers/hot water/steam/or any other "help")use car de icer...and dry thoroughly.also, if too full, it will frost up around the top.
Aug 22, 2010 | Freezers
Trying to find parts for a Holiday brand chest freezer
Try on amazon, take a look here: Amazon com chest freezer parts. Wish you best of luck. Cheers
Dan
Feb 26, 2010 | Freezers
Freezer not freezing!
try plugging the electric cord into a receptical
Feb 18, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
When plugged, kenmore freezer shorts the surge protector and outl
if thats the case should be an apparent wire off, somethings shorting directly to ground. the chest freezer has all of its wiring behind the access panel on the side of unit , no other wires in machine id look right there for something obvious
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
346 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
