Question about Sony Playstation 3 (PS3) Console
After switching my playstation 3 on it switches straight back to a flashing red light
  • 4,102 Answers
Hi, its not good news im afraid the reason it shuts down and gives you a ref light is due to damage being done to the circuit board inside the ps3.
it could be that it has over heated which is often the case this could be down to dust build up or if the heat sink paste on the gpu and cpu chip has gone brittle or if you have been using the ps3 on carpet or in top of anything else that gives off heat such as dvd or sky box, these cause it to over heat really quick.
right now you have a couple of options if you have any warranty left take it back and get a refund if your warranty has run out then you could try getting it repaired but their is no guarantee the repair will work or how long it will work after the reapir.
as you have got the red light this does mean the console has over heated and their is a fault with the board so its not going to work again the way it is.
now i repair these for 25 quid plus parts so you need to look around if you want it repaired and see what the best price you can get.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
ps3a1
Posted on Sep 30, 2010
4 Suggested Answers
  • 241 Answers
SOURCE: Playstation wont switch on, comes on and then
Over heating issue easily fixed look here http://www.slashgear.com/complete-ps3-problem-list-172513/
Posted on Mar 23, 2010
  • 1139 Answers
SOURCE: playstation 3 switches off and red light flashes
Sadly this is what is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps
Posted on Oct 27, 2010
Peter Fix
  • 187 Answers
SOURCE: My playstation won't switch on. The red light
hey there alison
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Posted on Sep 01, 2011
Flashing red light will not eject game
if you turn it on, and it goes green then yellow then beeps 3 times and flashes red, then your ps3 has overheated and been damaged. you can fix it with the heat gun trick, http://www.youtube.com/watch?v=4_Ic1_TY-GU
but it will only break again.
try flipping the switch in the back, then hold the eject button while you flip the switch back on, that should eject the disc.
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
I can switch the ps3 on and it goes of straight away with the red light flashing
hi
you have to reflow your cpu chip (on mainboard)
its not your job - take it to an expert
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
The playstation 3 just turns off and the red
Over heating, I myself had this problem, A good fix is to get some Caned Air and blowout any dust that is in the playstation via the side front and rear ports.
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Playstation wont switch on, comes on and then switches itself straight off and a red light flashes, can anybody help??
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
My ps3 switched off by its self recently and when i tried to switch it back on the power light was flashing red i pressed it once and it turned solid red then pressed it again it went green for around a...
Yes this is the YLOD (Yellow light of death) to fix it you need to stop the heat build up getting to the main chips in the motherboard to do this you should use the recommended PS3 Repair guide.
It is created by the same person as the top selling Xbox guide>>
PS3 Repair Guide
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
When I switch my playstation3 on from standby it switches straight off gives 3 beeps and then has red flashing light
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps.
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
916 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
