Question about Dell OptiPlex GX240 PC Desktop
Optiplex GX-240 no reconoce la unidad de cd rom
ljoosepson
  • 16 Answers
SOURCE: i have a dell optiplex gx 260 and it says that
If you click on my computer then you should be able to see A:, C:, D:, E:, H:? If you're still having some problems with locating the harddrive then you should look on the left side of the screen and see system tasks, Other Places and Details. What you should do is click on view system information and system properties should come up with several options to choose from. I want you to click on hardware and go to device manager and you'll see a list that displays all the hardware devices. You can start with disk drives and troubleshoot it under general and also check on the update driver under driver. You can also go to settings under start and click control panel. Once you're in then click add hardware and located the harddrive and cdrom. It'll probably go into self check diagnosis for you to go through step by step. if you have diagnostics window? click on it and go step by step until the problem is soft. Once everything is in the clear then you should click start to turn off the computer and restart it yourself. Once everything goes through then you shouldn't have any problems. However, if you're still having problems, let me know and I'll take you through it step by step.
Posted on Jun 08, 2009
  • 42 Answers
SOURCE: What is the exact mane of the DVI to VGA adapter
Sorry, but what do you mean with mane (can't find a correct translation to dutch)
Do you mean advantage, or do you mean what you can do with it?
Normally a DVI to VGA adapter can be used to connect a display with a VGA connector to a DVI port. If you have 2 ports VGA and DVI, maybe you can connect 2 displays to your pc. It's great working with multiple displays, making your desktop twice the size. For example: you can open your mail program in one display and your web browser in the other.
Posted on Jul 22, 2009
  • 115 Answers
SOURCE: dell optiplex gx 240 cannot boot from CD rom every
at the same time goto set up screen by pressing f2 and then change the boot sequence as cd drive to be first boot device and then try to boot from cd and as soon as you restrt and after dell logo it giuves you a message press any key to boot from cd at the same time press space bar be very quick as you have only 2 seconds to press the key or it wont boot if that does not work then the problem is with the cd drive.
Posted on Oct 27, 2009
  • 561 Answers
SOURCE: my hard drive crashed on my dell optiplex gx 60 i
Hi
Please try the following
Click on F12 or del tto enter bios setup when you first switch the power on
go through the options until you find Boot sequence
Choose the CD rom drive from there and ensuring the CD is in the drive save the settings and restart this will allow the CD drive to be picked up
Please can i ask that you leave feedback and vote if this has been useful
Posted on Feb 11, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: what ethernet card to install Dell Optiplex GX
You can use any brand of Ethernet card in this computer as long as it will fit in the case. If your GX240 is packaged in the small form factor case, you'll need a low-profile card. (Low-profile cards have a shorter mounting bracket than regular-size cards which won't fit this case.) For the small desktop and mini-tower cases you can use any card.
If you want to avoid having to open the case and fit a new card, consider a USB Ethernet adapter. All you need to do is plug it in to an available USB port and you're done. No opening the case and worrying about installing a card. These adapters are available at some retailers and through online vendors.
Whichever way you go, just be sure to go into the computer's BIOS settings and disable the integrated network connection.
Hope this helps. Thanks for using Fixya!
Posted on Feb 15, 2010
Testimonial: "Thank you! Have ordered D-Link DFE-530TX+ 10/ 20/ 100/ 200Mbps PCI Network Adapter 1 x RJ45 for $9.99."
No reconoce sata RC410-M asterope2
Hay varias razones posibles de su SATA no funciona. Se puede desactivar en la BIOS. Si usted sabe como, entrar en la BIOS y ver si esta apagado. Si es asi, vuelva a encenderlo. El cable SATA podria estar danado o defectuoso. La unidad de disco SATA puede resultar danado o defectuoso.
El cable de alimentacion SATA podria ser defectuoso, o el dispositivo no este conectado a la fuente de alimentacion. La fuente de alimentacion puede ser defectuoso o seccion SATA de la fuente de alimentacion puede estar defectuosa.
Espero que esto sea algo util para usted. Tuve que usar un traductor para responder a su pregunta, asi que por favor me perdone si esto es dificil de comprender.
-Denny
Feb 13, 2014 | Microsoft Windows XP Home Edition
Hola mi lectora no lee los CD?,
Haga clic en iniciar el control de las herramientas administrive panel, administraci?n de equipos, administrador de dispositivos, despl?cese hacia abajo cd-dvd rom unidades puede ver un signo de interrogaci?n amarillo? bot?n derecho del rat?n tendr? opciones para actualizaci?n del controlador, Volver al controlador anterior o seleccione las propiedades generales de solucionar problemas, seleccione el controlador, haga clic para volver a instalar los controladores de clic en Actualizar controlador o desinstalar y reinstalar, si esto no soluciona el problema puede ser que sea un problema del registro si no puede ver su unidad de disco en el Explorador de Windows
Cierre todos los programas
Haga clic en Inicio, Ejecutar y escriba regedit y oprima
Haga clic en el signo m?s (+) junto a las carpetas siguientes
HKEY_LOCAL_MACHINE
SISTEMA
CurrentControlSet
control
clase
{4D36E965-E325-11CE-BFC1-08002BE10318}
Esta carpeta es el reproductor de DVD / CD-ROM Descripci?n de unidad de clase en el registro. Busque cualquiera de los siguientes nombres en la columna de la derecha.
Filtros de alta
Filtros de baja
superior Filters.bak
menor Filters.bak
Si alguna de las teclas de arriba se muestra en el paso 4 en la lista, haga clic derecho sobre ellos y elija Eliminar Despu?s de eliminar las teclas, cierre el editor del registro
Reinicie su computadora
Abra Mi PC y compruebe si su unidad de CD o DVD han regresado. Tambi?n es posible que desee abrir el Administrador de dispositivos y verifique que el signo de exclamaci?n amarillo y el c?digo de error en la unidad de CD o DVD se ha ido. o
puede que tenga que desconectar f?sicamente los cables de este cd / dvd luego enchufe de nuevo este debe activar el Asistente para hardware nuevo o
puede que tenga que desinstalar y reiniciar el equipo vuelva a instalar el reproductor de DVD / CD vuelva a instalar el controlador de este dispositivo
Si el equipo viene con un disco de la placa base los controladores podr?an estar en ella
haga clic en Inicio, Panel de control de las herramientas inform?ticas de gesti?n administrive administrador de dispositivos, despl?cese hacia abajo cd discos DVD-ROM si usted ve una cuesti?n de color amarillo o signo de exclamaci?n? ! o una X roja, haga clic derecho tendr? que actualizar el controlador o
Sep 09, 2011 | LG CRD 8521B Internal 52x CD-ROM Drive
Como combertir el coyote hunter a 11 metros
  1. Quite la cubierta superior de la unidad y busque las resistencias en la parte inferior de la tarjeta principal
  2. Desoldar, y saque a los que es.
  • Si usted tiene el modelo más nuevo con los Mosfet en que el uso esta conversión
  1. Quite la cubierta superior de la unidad y busque la fila de 15 pines en la parte delantera de la unidad. Desoldar el cable de tiro corto desde el 7. clavijas a los pines 11 y 12 (conectados entre si).
  2. Desoldar el puente de soldadura cortocircuito de los pines 11 y 12 de modo que son pernos independientes sin relacion entre ellos
Un cordial saludo, Tony
Apr 26, 2011 | Connex 3300 240-Channels Base CB Radio
Mi unidad de cd rom solo lee cd de musica y los de datos hacen que se bloque el equipo me toca sacar el cd de datos para que se desbloque
Intenta limpiar el lector de la unidad
venden unos kits limpiadores para eso
Si no funciona intenta actualizar los drivers de la unidad de CD
saludos
Mar 31, 2011 | Computers & Internet
Tutoreal recovery con discos
There is a good tutorial here but in English. Maybe use google translate to help you if problems
http://www.pctechbytes.com/hp/hp-recovery
translation from google
No inserte ning?n disco en el HP Pavilion antes de comenzar.Desconecte todos los perif?ricos y dispositivos internos no preinstalado en el PC, excepto el monitor, teclado y rat?n.
Encienda el ordenador y pulse la tecla F1 cuando la pantalla del logotipo aparece por primera vez.
Pulse la tecla de flecha derecha hasta que de inicio se destaca.
Pulse la tecla de flecha abajo hasta Boot Device Priority se destaca.Recuerde que el CD-ROM est? en la lista.
Pulse la tecla Intro, a continuaci?n, pulse la flecha hacia abajo y resalte la unidad de CD-ROM lista.
Pulse el signo m?s (+) hasta que el CD-ROM est? en la parte superior de la lista.
Inserte el primer disco de recuperaci?n en la unidad de CD-ROM.
Pulse el bot?n ENTER para guardar los ajustes y salir. Una pantalla de recuperaci?n parece.
Lea y responda a cada pantalla de recuperaci?n que aparece. Al cambiar los discos, no
pulse el bot?n OK. En su lugar, esperar a que la unidad para leer el disco y que autom?ticamente continuar la recuperaci?n.
Despu?s de la recuperaci?n es completa, restablecer la prioridad de CD-ROM de arranque del dispositivo a su configuraci?n original, de la siguiente manera:
Utilice las teclas de flecha para seleccionar Boot Device Priority en el men? de arranque.
Pulse la tecla Intro, a continuaci?n, pulse la flecha hacia abajo para resaltar la unidad de CD-ROM.
Pulse el signo menos (-) hasta que el CD-ROM se encuentra en su ubicaci?n original.
Reinicie el equipo.
Despu?s de la recuperaci?n del sistema se ha completado, y el equipo se inicia correctamente, actualice el software de la siguiente manera:
Actualizaci?n de las definiciones de virus del sistema.
Obtenga las ?ltimas actualizaciones cr?ticas del sistema con Windows Update de Microsoft.
Actualice el software de HP en el sistema.
Mar 02, 2011 | HP Media Center 864N PC Desktop
Hola: tengo problemas con mi portable super multi driver LG GP08NU6B, ya que mi Pc no lo reconoce, cuento con el windows 7; y pienso que el problema es por que ya tenia antes instalado otro lector de...
A mi me ocurre exactamente lo mismo, en una netbook donde no tenía ninguna grabadora instalada funciona ok, pero en la pc de escritorio o en la notebook no funciona, todas tienen windows 7. El soporte telefonico o via mail de LG me mandan a la tienda donde la compré...!!!! Es raro,le busque varias soluciones pero no logro hacerla funcionar!!!
Jan 23, 2011 | LG GP08NU6B DVDWriter Black External...
Mi pc PCChips Con la placa madre m955g v3.0 reconoce Enciende discoteca El duro y sí Apaga Que servicios PUEDE , Como lo soluciono , gracias
hola a todos tengo un problema con mi c.p.u.... ella tiene una tarjeta madre M955G V3.0 a Y es una pc chips,,, bueno la primera falla que presento fue que no ensendia.. le limpie la ram y nada hasta q le quite el junper de la bios para resetear.. y desde alli encendio la pc pero ahora no me reconoce el DISCO DURO NI LA UNIDAD DE DVD... SI ME AYUDAN SE LO AGRADESCO
Sep 17, 2010 | PC Chips M955G Motherboard
Formatear mi laptop Dell inspiron 1526 mi correo es: pazl136@hotmail.com
guarda tu informacion primero, luego introduce el cd o dvd de winodws , reinicia tu maquina , cuando la secuecia de booteo reconoce la unidad de cd/dvd aparece una leyenda que dice presionar tecla para continuar y lo haces , luego sigue los pasos q aparecen ahi
Aug 01, 2010 | Dell Inspiron 1526 Notebook
Muchas gracias mi problemas es que mi presario 700 no reconoce ningun disco duro y ya hsta le he cambiado la tarjeta done va el disco duro montado que puedo hacer, no se apresia ninguna anomalia en la...
Pon tu disco de instalación de Windows en la unidad y reinicie el equipo. Al arrancar, presiona F2 (o F12) y establecer la secuencia de arranque para "arrancar desde el CD" Instalar Windows programa detectará el disco duro e instalar el sistema operativo en ella. Si no lo hace, el disco duro ha fallado.
Mar 29, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Dell OptiPlex GX240 PC Desktop Logo
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
