Question about Frigidaire PLEB30T8A Electric Double Oven
Oven not heating KitchenAid KERC506HWH3
The oven does not heat. Everything on the range works including the display. When you turn on the oven you can hear clicking noises but it will not activate the heating elements. I tried all the combinations of convection, bake, preheat and broil. Is this a problem with the oven sensor or the control panel? How do I tell? How do I test the sensor to see if it is working? I have a 2006 electric Frigidare oven that will not heat up the burners on top work and when I turn the oven on it looks like it is working on the display but it will not heat up I can try to turn on self cleaning and the door will lock but it still will not heat up same thing with the boiler wont heat up at all in oven. I just used it fine the night before. Can some one help me figure out how to fix this? I have the same thing going on in my 50's version of general moters frigidaire, the burners work along with all the displays, and the back of the oven gets hot and so does the plate warmer, but the oven will not heat up. I have tightend every conection possible but when it stopped working one day, it never did again.
  • asconner Oct 11, 2008
    my oven has this same type of problem but it will turn on but it will not go above 290 degrees
  • Anonymous Feb 24, 2009
    i have the same problem did the fuse fix work?
  • 413 Answers
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
Posted on May 31, 2008
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid Superba electric convection oven not preheating right
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
How do I turn off demo mode for KitchenAid Model KEBS179BSS00
The following is from your Users Manual:
Demo Mode IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without heating elements or burners turning on. If this feature is activated, the oven will not work.
1. Press OPTIONS until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START to save the setting.
5. Press OFF to exit and display the time of day http://www.kitchenaid.com/digitalassets/KERS306BSS/Use%20and%20Care_EN.pdf
Feb 19, 2015 | KitchenAid Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
This is probably the thermal shuttoff fuse. Usualy mounted in the back of the oven. Aftermarket fuses are resetable but the OEM ones that come with the ovens usualy are not, so when they go out they stay out. This shuttoff only effects the power to the element so the rest of the oven appears to work.
The oven has to come out and remove the rear covers, behind the covers you will see 2 wires that go to a small 1/2 in dia "plug" that mounts directly to the surface with 2 screws.
Remove the connections and put a meter across the cuttout. it should read very close to zero ohms, if not its blown.
Apr 23, 2009 | Frigidaire FEB27T5D Electric Double Oven
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Frigidaire PLEB30T8A Electric Double Oven Logo
375 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
