Question about McCulloch Garden
I look a pieces for gas cut border, model: M26, 26cc, (rubber gasket for three enter pipe) gas tank
  • 119 Answers
SOURCE: How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Posted on Mar 28, 2010
  • 454 Answers
SOURCE: One piece toilet needs a new gasket. How do I replace it?
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
Posted on Jun 04, 2010
  • 10865 Answers
SOURCE: the rubber hose conecting the pipe to the gas tank
Hello. Your best bet is to replace it. This is a common item available at any auto parts store. J.
Posted on Jul 10, 2010
2strokeguy
  • 183 Answers
SOURCE: I changed all of the
The leak at the fuel tank is not related. Sorry. What you have is a blockage in the carb itself. Take it back off, take it apart and carefully clean all the orifices. In the plate under the primer bulb, there is a one way valve. Make sure it is clean, use aerosol carb cleaner and spray thru the valve. Remove the locks from the adjustment screws and remove the jets one at a time and blow carb spray thru them also. If you did not replace the strainer screen before, replace it now. It is located under the plate nearest to the fuel inlet. When reassemble, make sure the gaskets are in the same order as the originals. Diaphragm side...paper gasket against the carb body, then diaphragm. On the inlet side, thin cellophane first, then the thicker gasket, then the outer plate. The adjustment screws should be turned out 1.5 to 2.0 turns.
Posted on Sep 21, 2010
SOURCE: Where can I purchase genuine parts urgently for Daelim Daystar VL125 from UK
don't know if they have exactly what your looking for but have a look on this site
http://www.hyosungsource.com/index.php?main_page=index&cPath=83&zenid=kvg5hpnb591v7hrj2p044rrfv2
Posted on Feb 20, 2013
Why wont fuel go into tank?
Really sounds like someone or something has plugged up your fill pipe. Is there any chance someone has done this?
For a fix, if you will look under the car, you will see a place where the metal fill pipe meets the metal extension coming up from the gas tank. Between them is a rubber hose with a metal clamp on each end. You could loosen those clamps and remove the rubber pipe, and then see if something is plugging that, and where. The gas tank is removable, but both that and the rubber hose will be a "big job'.
God bless your efforts.
Jun 01, 2015 | 2003 Pontiac Grand Prix
I have A briggs & stratton 300 engine. When I start the motor surges at idle and full throttle.
Leaking head gasket or intake gasket
Try a new spark plug & fresh fuel first,
& clean the air filter
Sep 26, 2014 | ROPER OUTDOOR POWER PRODUCTS Weedeater 20"...
Replace fuel pump
Best to do this in a well vented area because of the fire hazard, so that the gas fumes don't accumulate.
1) Disconnect battery negative cable.2) Jack up car and support on safety Jack stands3) Siphon gas out of tank4) Remove three rubber hoses on rear of tank. These are used for gas fill up; remove hose clamps and disconnect.5) Remove three hoses from front of tank; these hoses go from the fuel pump to the engine. You'll need special fuel line wrenches for this.6) Disconnect two connectors at the front of the tank.7) Remove two bolts that hold the exhaust pipe heat shield. You'll want to use penetrating oil on these; they will be corroded.8) Support tank with a floor jack. Remove the bolts which hold the tank in place. Pivot the tank on the exhaust, tilt and slide out.9) The gas hoses are taped to the tank. Remove the hoses. The fuel pump plate has about 12 screws around it. Remove the screws. Lift the plate out. The fuel pump is retained with one screw. Remove the screw. Filter is retained with a clip; remove it.10) Get your new fuel pump ($250), the rubber gasket for the fuel pump plate, and new filter ($5). Compare the pump with the old one; it must be the exact lenght. I had to go to two different auto parts stores before I got the right one.Installation is opposite of above. Good luck!Fuel pump is not too tough. First, get a Haynes or Chilton manual for reference (about $14).Best to do this outdoors, so that the gas fumes don't accumate. If I recall correctly:1) Disconnect battery2) Jack up car3) Siphon gas out of tank4) Remove three rubber hoses on rear of tank. These are used for gas fill up; remove hose clamps and disconnect.5) Remove three hoses from front of tank; these hoses go from the fuel pump to the engine. You'll need special fuel line wrenches for this.6) Disconnect two connectors at the front of the tank.7) Remove two bolts that hold the exhaust pipe heat shield. You'll want to use penetrating oil on these; they will be corroded.8) Support tank with a floor jack. Remove the bolts which hold the tank in place. Pivot the tank on the exhaust, tilt and slide out.9) The gas hoses are taped to the tank. Remove the hoses. The fuel pump plate has about 12 screws around it. Remove the screws. Lift the plate out. The fuel pump is retained with one screw. Remove the screw. Filter is retained with a clip; remove it.10) Get your new fuel pump ($250), the rubber gasket for the fuel pump plate, and new filter ($5). Compare the pump with the old one; it must be the exact lenght. I had to go to two different auto parts stores before I got the right one.Installation is opposite of above. Good luck!
Read more: http://wiki.answers.com/Q/How_do_you_change_a_fuel_filter_for_a_92_geo_storm#ixzz27tyFTkDd
Sep 29, 2012 | 1990 Geo Storm
Have a check engine Light and the shop says it is gas cap..reset check engine and all was well for about three weeks and back on again. Checked the gas cap and when you tighten the cap it continues to spin...
There is a rubber gasket on your gas cap, normally that is the problem. If it doesn't seal tight enough the tank isn't pressurized and that sets the error codes. You can either replace the gas cap or replace the seal or add another rubber gasket.
On my Lincoln, I was getting that code quite a bit, even after replacing the gas cap, so I added another rubber gasket and haven't had that code again.
Aug 12, 2011 | 2006 Porsche Cayman S
The three-bolt gasket seal between the upper half and the bowl; how do you get the plastic water flow out from the gasket?
I assume you have separated the tank (the upper part) from the bowl. The rubber gasket just pulls off. Under the gasket you will find a large nut holding the plastic flush pipe to the bowl.
Dec 14, 2010 | Kohler K-11466-0 White Cimarron Comfort...
Hitachi Gas Air Compressor just stops running
The problem that you describe could be fuel lock due to failure of vent system in gas cap. Easy to check; leave gas cap loose run engine as normal. If problem gone, replace cap with new vented cap. The newer gas caps (California caps) have much smaller vent holes that seem to clog when moving the compressor at too steep of angle causing gas to enter cap choking vent. Temp fix would be to cut small piece from rubber gasket large enough to let air to enter tank. Good luck with your repair.
Jun 29, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
Fuel leaks from filler pipe to gas tank
You don't need to replace the gas tank, the filler pipe is connected to a rubber hose which connects to the tank with clamps at each end.
Mar 08, 2010 | 1995 Toyota Camry
85 Bronco 351w fuel leak
Sounds like you are rusted out. Even the factory parts are not that expensive and they are properly bent. Check the dealer.
If substituting aftermarket piping you want to either replace the bad section with a splice or the whole piece. Notice the end connections and where you will attach the replacements.
Notice the routing of the gas line away from hot exhaust parts and areas a lift jack will crush your line. Notice what moves close to the fuel line to allow for travel.
You may be able to splice a piece of rubber fuel line into a metal line with a few clamps.
I have seen everything you will need at Autozone and Oreillys and similar stores with the exception of Factory parts.
Sep 13, 2009 | 1985 Ford Bronco
Hole in the smog line that leads across the gas tank.
You should be able to put a piece of rubber fuel line over the section with a hole, clamp both ends. If it's hard to get to, run a long piece of rubber fuel line (inside diameter big enough to fit over smog line), cut the original smog line, attach new rubber fuel line over cut section, wiggle it over the tank to other side where you can cut original line again, and attach both ends with hose clamps. Let me know how it goes, it should work, you can even go around the tank front or back, just make sure you use zip ties or something to keep the hose from hanging down.
Aug 19, 2009 | 1993 Ford Ranger SuperCab
Same Problem with the 4.5hp B.S. 21" Yardmachine Walkbehind Mower
This is what I would do... Remove the fuel tank and carb assy.. Two bolts, one behind the gas cap and one on the end of the tank. Pull it straight off the intake pipe then unhook it from the throttle link. Now, unscrew the carb from the tank. Clean the carb with a can of carb cleaner. Slip the screen off the pickup and make sure it's clean. Discard the pump diaphragm and gasket. Buy a new pump diaphragm kit, part #795083. Clean the top of the tank where the pickup with the screen fits into. Put it back together. Remember to put the rubber diaphragm against the tank and the gasket on top of it then the carb. Don't forget to attach the breather tube when you're putting it back on the engine. That should fix 'er up. Also, if the rubber ring and plastic retainer ring came off on the intake pipe when you pulled the carb and tank off, put them back in the end of the carb before sliding it back on the intake.
Jun 17, 2009 | Yard Machines 24a 021h700 4.5 Horsepower...
Garden Logo
116 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
