Question about Magellan GPS 315 GPS Receiver
How to reset Magellan gps 315 - Magellan GPS 315 GPS Receiver
SOURCE: Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Posted on Jul 25, 2007
SOURCE: Case cracking Magellan 315
I was able to open a 315 by starting at the bottom with a screw-driver placed in the gap between either of the two cross ridges and twisting the screw-driver.This opened a gap at the bottom which I followed around the perimeter with the screw-driver until both halves seperated fairly easily.
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: MAGELLAN GPS 315, LCD Not filling out completely
I just got my GPS 315 open, thought it may have zebra connectors.
You will break the wires from the data connector in opening this beast. There is a photo on this site showing the wiring.
It is a wired panel the connections to the LCD uses some super adhesive that gives way after a time. It appears unrepairable.
I have two early 7 inch LCD TVs with the same problem.
There is NO markings as to part number or manufacture so the panel
will be unavailable. So I would suggest to use it as is or use it with an early laptop with a serial com port.
Gary G
Posted on May 26, 2009
SOURCE: i am an eagle scout in need of a manual to use a gps for an award
I have an Adobe PDF of the instruction manual.
Send me an email at flaggie@supernerd.com.au
Posted on Aug 23, 2009
aloha27
  • 693 Answers
SOURCE: manual for magellan gps 315
Hi1 Here's the link for your manual!
http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Posted on Apr 10, 2010
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
I need a user guide Magellan 315 for (PDF File)
here is the link to your manual http://oneresponse.info/resources/imtoolbox/publicdocuments/GPS%20-%20Magellan%20315320.Pdf
May 08, 2011 | Magellan 12, 310, 315, 320
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
AM LOOKING FOR A MANUAL FOR MAGELLAN GPS 315
(magellangps.com/support/product.asp?prodid=2)
You can use this link to download manual.
Apr 24, 2010 | Magellan GPS 315 GPS Receiver
Gary G
Apr 14, 2009 | Magellan GPS 315 GPS Receiver
The only method I have found is with a dremmel tool and cut it open along the original split line.
All the electronics are clear of the case mid line. The case is a bit less than 3mm thick.
The antenna is closest with maybe a 2 mm clearance all round and the various (6) rear conector wires (on the right looking from the back) have a similar clearance but sit below and away when the unit is assembled. Cheers
Dec 16, 2007 | Magellan GPS 315 GPS Receiver
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
Magellan GPS 315 GPS Receiver Logo
114 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
