Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer heat always hot, regardless of very low temp setting or wrinkle free setting.
5 Suggested Answers
  • 1073 Answers
SOURCE: Dryer drum turns but
whar is the model number
Posted on May 05, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
SOURCE: dryer has heat..but very low temp , takes forever
Buy a new dryer welebicho
Posted on Nov 10, 2008
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 17, 2015 | Dryers
Kenmore dryer MOD# 110.61402310, Dryer heats up and is SUPER hot. Clothes are to hot to take out after. Seems like timer is messed up because it will run until you open the door. Only has one heat set
OVER HEATING HAPPENS ONLY IN ELECTRIC DRYERS NOT GAS DRYERS.... HERE IS A VIDEO FOR HELP ON THIS..
Oct 28, 2014 | Dryers
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
GOD IS still GOOD !!!!
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 16, 2014 | Asko Dryers
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Bosch dryer wta3500ug start runing gos on and off over and over with no heat...?
nizaraaa:
What you are describing sound as if you have the dryer set on a Wrinkle Sheild setting which it will go on and off for a set time with a low heat, so wrinkles do not set in the clothing.
woodychoppers
Oct 31, 2008 | Bosch Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
156 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
