Question about T-Mobile G1 Android HTC Google Smartphone Brown Cell Phone
My phone has stopped working properly. i did a factory reset which hasnt helped. the w,e, and r keys all seem to lock the phone. also it wont connect to 3g so i cant sync it to the googlemail account.
    Guru:
  • 468 Answers
It happens when the process is malfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
Posted on Oct 26, 2010
How do I hard reset my virison lg vs920 modle phone
Follow the following steps:
  1. Turn the Power Off.
  2. Touch and hold the following keys at the same time for 8-12 seconds: Power/Lock Key + The Volume Down Key.
  3. Press the Power/Lock Key when you see the pop-up "Permanently Erase User Data & Reset Settings?". Press the Power/Lock key to confirm, or touch any Up and Down key to cancel.
  4. When you press the Power/Lock key to confirm, another pop-up stating "Are you sure you want to continue with erase?" will show up. Press the Power/Lock key to confirm or touch any up or down key to cancel.
  5. After pressing the Power/Lock key, your phone will be restored to factory settings.
Please remember that when you perform factory reset, then all your user applications and user data will be deleted.
Please make sure you back up any important data before a factory reset. I recommend Titanium Backup (https://play.google.com/store/apps/details?id=com.keramidas.TitaniumBackup&hl=en). However, your phone should be rooted.
The picture attached should show you the buttons highlighted in green.
However, if your phone is still in working condition, then you can follow the following steps:
  1. From the Home screen, touch the Menu Key.
  2. Touch Settings > Privacy > Factory Data Reset.
  3. Note: Touch the check box to erase all contents from your microSD card when the phone is reset.
  4. Read warning and touch "Reset Phone".
Hope that helped.
Cheers,
Sami Memon
Aug 17, 2012 | Cell Phones
Won't finish booting
Sounds like a corrupt operating system you can try the master reset steps below WARNING ALL PERSONAL DATA WILL BE LOST UNLESS STORE ON THE SD CARD
Other wise contact your provider via website or phone for the closest repair center
http://locator.t-mobile.com/Locator.aspx
  1. Back up all necessary data.
  2. Turn off the phone.
  3. Press and hold the Volume Down and Power keys.
  4. Wait 3 seconds and press the Back and Menu keys.
  5. Note: If you see the LG logo before pressing the Back and Menu keys, the reset hasnt been completed and you will need to restart.
  6. Release the Power/Lock key after you see the LG logo.
  7. Release the remaining keys after the LG logo flashes (blinks once).
  8. The Android Unpacking screen appears.
  9. The phone will restart and complete the factory reset.
May 28, 2012 | T-Mobile My Touch Cell Phone
My car will not crank up and my headlights wont cut off what can i do
The onboard computer/security system probably has a broblem with the fact that it has not been fed properly for quite some time and is still delerious from malnutrition. Try connecting the battery then locking and unlocking the doors with either the remote unit or the door key. This will get the security system to reset.
May 26, 2012 | 1999 Mazda Protege
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
How to format nokia N79 phone?
1) Factory defaults-
Type *#7780# on your standby screen.
This will reset all your setting to default factory settings. User data wont be affected. (Default Lock code is 12345)
2) Soft reset-
Type *#7370#
This will reset the phone as well delete user data. Use when want to format the phone.
Jun 03, 2011 | Nokia N79 Cellular Phone
The vibrate setting has stopped working. Vibrate doesn't work at all. Is there a way I can fix it?
Please try resetting the phone but this will reset all the settings to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Unlock the screen by touching Lock or pressing the Unlock Key on the left side of phone, then touch Menu to access the menu .
  2. Touch the Settings & Tools icon.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. Touch OK after reading the warning message.
  8. Touch Revert. A confirmation message is displayed briefly before the phone resets itself.
source: http://www.resetcellphone.com/solution/LG/vx9700-dare
Feb 22, 2011 | LG Dare VX9700 Cell Phone
Keys have stopped working properly, will lock
Manual unlock door start car. The car battery was low and could not respond to key. If it win't start charge or jump it. Do not disconnect the battery unless you have to some systems require special codes for radios and other equipment. You may have to get the auto club to open the door for the hood release and jump you there. I don't feel bothe remotes batterys went bad at the same time but. The last resort is to change one and try it. Don't expect radio shack to replace your battery for your remote try calling a locksmith or the dealarship. Some dealerships are quite helpful...depends on where you live.
Aug 17, 2009 | Vehicle Parts & Accessories
Reset phone to factory setting.
kindly have an software updation in your mobile
Jul 23, 2009 | Cell Phones
T-Mobile G1 Android HTC Google Smartphone Brown Cell Phone Logo
43 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
