Question about Craftsman 25cc Gas Line Trimmer
I have a craftsman trimmer and removal of the hub has proven difficult. Is there a method that I'm missing from the procedure?
    President:
  • Craftsman Master
  • 1,545 Answers
By referring to "hub", do you mean the string head at the end or the round metal clutch drum at the end of the crankshaft? Post back as I would like to help.
Posted on Oct 03, 2010
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
All I need to know is how to change the belt on a Craftsman 22 inch Weed Trimmer. #917.773710. Can't find the manual. Didn't think it would be this difficult to have such an easy question answered....
You can find a diagram for your mower here. You should be able to remove the top cover, then loosen the tensioner pulley and pull the belt right off. Put your new belt on following the original belt path. You can find a replacement belt at PartsBuggy.com here.
Aug 26, 2011 | Craftsman 25cc Gas Line Trimmer
Craftsman line trimmer difficult to start but when I get it going it stalls after a minute or so. Sometimes before it stalls, it revs up other times it just slowly loses power and stalls. Can anyone...
I'm not sure the make of your carburetor, but it probably just needs a slight adjustment of the L (Low) and H (High) mixture needles.All diaghragm carbs are about the same. If you can access them, try removing them and spraying the circuits with carb cleaner and replace them at about 1 1/2 turns open from a lightly seated position. Don't mix them up. Here is the final adjustment.
http://www.zamacarb.com/tipspage.html
Oct 20, 2010 | Craftsman 25cc Gas Line Trimmer
How to I change the spring for the start-cord on a Craftsman Sim-pul weed wacker? p/n 530-059225
A bit of disassembly will be required for you to reach the point where you can access the starter/recoil unit. If you already have done so, it will be evident that you have to take the unit out, remove the old spring, install the new spring (paying special attention to the orientation of it in the pulley hub) and reinstall. Torx fasteners hold most all of the parts on this machine. If you take your time and don't rush it, it is not too bad. Check this site with your Make and model # for parts diagrams and breakdowns.
www.searspartsdirect.com or go to
http://www.ereplacementparts.com/ if you like.
Aug 16, 2010 | Craftsman 25cc Gas Line Trimmer
How to sharpen craftsman 14 inch hedge trimmer?
Unless you have a surface grinder they are difficult to do without causing more harm than good, take the trimmer to a pro with the right equipment.
Jun 02, 2010 | Garden
How to replace 99 gmc 3/4 tom brake rotors
Removal & Installation
  1. Remove 2/3of the brake fluid from the master cylinder.
  2. Raise and support the vehicle.
  3. Remove the tire and wheel assembly.
  4. Remove the front wheel hub extension (dual wheel vehicles only).
    • Insert a drift or large screwdriver through the brake caliper into one of the brake rotor vanes in order to prevent the rotor from turning.
    • Mark the relationship of the front wheel hub extension to the hub
    • Remove the front wheel hub extension bolts
    • Remove the front wheel hub extension from the vehicle. It may be necessary to tap around the perimeter of the hub extension with a rubber mallet to loosen it from the hub
  5. Mark the relationship of the rotor to the hub.
  6. Remove the caliper and mounting bracket as an assembly.
  7. Hang the caliper and the mounting bracket assembly from the suspension using mechanics wire.
  8. Remove the rotor.
  9. If the rotor is difficult to remove due to corrosion in the hub area use the following procedure to remove the rotor (25 series only).
    • Clean all the surface areas and the threaded holes of contamination
    • Generously apply penetrating oil or the equivalent to the hub/rotor area
    • Insert (2) M10 x 1.5 bolts (jack screws) into the threaded holes of the rotor
    • Tighten both bolts evenly to force the rotor from the hub.
To install:
  1. Clean all rust and contaminants from the both side of the rotor and the hub flange.
    NOTE If the rotor was removed using the jack screw method you must ensure that the hub flange is free of nicks or marks caused by this procedure. Remove all raised nicks or marks before installing the rotor.
  2. Install the rotor.
  3. Install the caliper and the mounting bracket as an assembly.
  4. Install the tire and wheel assembly.
  5. Remove the safety stands.
  6. Lower the vehicle.
Oct 25, 2009 | 1999 GMC Sierra
Craftsman flipover head string trimmer. Will not start. No spark.
could be coil also could be a fouled,dirty flywheel,check coil wire
Aug 25, 2009 | Craftsman 25cc Gas Line Trimmer
TRYING TO REPAIR A CRAFTSMAN 4 CYCLE STRING TRIMMER MODEL #358.796121. I GOT THE CLUTCH HUB OF BUT CANNOT GET THE NEXT PART OFF. THE PART IS THREADED ONTO THE SHAFT AND SHOULD PROBABLY TURN COUNTER...
Hello kane8:
**To Hold the Crankshaft for Removal of the Clutch (or Any Component that Turns with the Crankshaft); Purchase a Bolt that is 3" to 4" Long and has the Same Diameter and Threads as the Spark Plug. Carefully Insert the Bolt Into the Engine Until it Contacts the Piston. If the Bolt is too Short, then Slowly Turn the Engine in the Same Direction you are Going to be Turning the Clutch Until the Piston Contacts the Bolt. Now to Remove the Clutch. If you do Not have the Clutch Tool for an Impact Wrench and are Doing this By Hand (no air compressor and/or not the correct socket), then Use a 2" Wide, Flat Chisel and a Shop Hammer or a 22oz Hammer and Hit the Outer Part of the Thick Ear in the Same Direction that the Engine Turns During Operation.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
233 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
