Question about Dishwashers
My ignis adl347 door will not close. there are no items caght in door or sticking out stopping it from closing. is there a problem with the latch?
    President:
  • 2,501 Answers
Check the shelf height. If your machine has an adjustable shelf (like mine), then if it slips out of position on one side, the door will not shut.
Try lifting up the shelf
Posted on Sep 30, 2010
06bmw pass.side door will not catch when push close how can get it to close
If what your telling me is that the door will go up to the latch and close no farther, then the latch is closed on the door. Hold the door handle open and stick a screwdriver in the hook that goes around the door post pin/ring and pop it open. It's just a hook that needs to be in an open and ready to hook position. The door will now close and latch.
Dec 07, 2017 | Cars & Trucks
Door locked and will not unlock and cant shut door
sounds like the door latch mechanism is stuck in the closed position. if you pull on the door handle and use something like a screw driver and pull the latch claws open the door should work. the latch is the part that closes around the door striker plate bolt to keep the door closed. lube the latch to help keep it from sticking again.
Sep 04, 2014 | Honda Accord Cars & Trucks
Ignis dishwasher beeps and flashes constantly
salt container is full of water
Mar 10, 2010 | Dishwashers
Driver side door will not close may be a broken bolt how do i fix this
Seems as though your door latch may have closed without having the door closed.
1. Use a screw driver of any kind to simulate the door latch pin. Stick this into the latch and put a small amount of tension on the latch pulling it to the inside of the car and actuate the door handle.
What you are trying to do is get the latch to move to it open door position. It might help to look at one of the other doors latches with the door open so you can better see this demonstrated and compare with your malfunctioning door.
If this all works out - make sure you take the time to lubricate the door latch assembly to prevent future problems of this sort..
Jan 29, 2010 | 1997 Chevrolet Monte Carlo
Cold morning driver door lock freeze
make sure the door handle on the outside has returned to normal position, sometimes the cold will make them stick. The door opens but the outside handle sticks open and the door won't latch. Hope this helps.
Nov 30, 2017 | 1998 Jaguar XK8
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
RADIO WON'T TURN OFF WHEN KEY IS TAKEN OUT OF IGNITION
sounds like you have a door ajar switch bad. spray some PB BLASTER lube available at parts store on the driver door latch assembley soak the latch assembley really good then open and close door 10 to 15 times and see if radio goes off.
Jan 14, 2009 | 2004 Ford F150
The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Jan 05, 2009 | 1995 Jeep Grand Cherokee
Door won't close - have to try over and over
I assume you mean that it won't latch. I think the lock mechanism is sticking. With the door open try to flip the latch on the door with your finger. It should make a sharp click. And you should be able to release it with the door handle. Check the passenger side door to get an idea how it should act. If it does not work easily, or does not click, you need to replace it. I think it is a dealer only item.
Jun 25, 2008 | 2000 Ford Focus
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
