Question about Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator
Kenmore Coldspot - both the refrigerator and freeze suddenly stopped blowing cold.
If the fridge is running and you can hear it cycling(click, ~5 sec, click), then pull the fridge away from wall, take cardboard access panel off, 1/4" hex head, attatched to the compressor(black dome shaped bout the size of a volleyball) is a relay, take it off, if it sounds like a baby rattler when you shake it, it's bad. Check this first. If yours doesn't have this, then it has a timer. Timer might be bad. Not telling the heater when to turn off. Which is causing the fridge to not continue cooling, obviously.
Posted on Oct 01, 2010
Kenmore refrigerator/freezer not cold! I have a Kenmore Coldspot model 57572791 refrigerator/freezer that suddenly stopped cooling/freezing. I took off the back & think it is the compressor @ the...
It is not likely, but since you had the lights on the same circuit it is possible that the breaker for that circuit may be tripped. Have you checked the breaker?
Jan 21, 2013 | Kenmore Refrigerators
My kenmore coldspot # 10659537990 gets to cold freezes everything have to turn off to get it to stop
Sounds like you need a thermostat. I suggest calling a reputable repair service. Seeing it is a Kenmore I would call Sears.
Hope this helps you...Jim...Please leave a comment
Feb 13, 2011 | Kenmore Refrigerators
A side by side kenmore coldspot the freeze is getting cold the refrigator side is very warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
heatman101
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
REFRIGERATOR OR FREEZER IS NOT COLD OR WILL NOT FREEZE
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Logo
162 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
