Question about Psion Workabout MX
Rcomw.exe does not want to run on windows 7 64bit machine.
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
CODE 43 WHEN CONNECTED
This is usually because the disc control board in the External drive has failed, Try it in a different portable case.
Sep 14, 2012 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Setup exe not running
If setup.exe is not running then main reason can be:-1. that file is corrupted or infected by virus.2. you donot have administrative right to run any setup on that machine.3. your windows installer problem or your system is also infected by virus
so first try another copy of that setup.exe file.then check your system for virus or windows problem if another file is also not working.
Feb 04, 2012 | Computers & Internet
How do I turn my webcamon ?
how to make my webcam work again , i have a msi cr500 laptop,windows 7,64bit,i think it can be my drivers an i can't seem to find the drivers for bison webcam
Oct 05, 2010 | MSI Microstar CR500438US Notebook PC
Just bought an new Windows Vista machine. Have
You must set this program to install and run in "Compatibility Mode" for windows 95.
Right click on the installer setup exe and choose run in compatibility mode and check for Win '95. Do the same for the main EXE of the program too, also make sure you run BOTH as "Administrator"
Jan 28, 2010 | Microsoft Windows Vista Business Edition...
I can't logon my toshiba portege m400 - s5032x a error message shows up saying Isass.exe application error the application failed to initialize properly (0xc0000005). Click on ok to terminate the...
Your system is infected by Sasser worm.The Sasser worm infects machines via network connections. It can attack entire networks of computers or one single computer connected to the Internet. The worm exploits a known windows vulnerability that is easily patched, however few systems seem to have this patch installed. It attacks Windows 2000 and Windows XP machines along with Windows NT and Windows Server 2003.
The patch from Microsoft known as the MS04-011 Security Update fixes the following vulnerabilities:
LSASS Vulnerability
LDAP Vulnerability
PCT Vulnerability
Winlogon Vulnerability
Metafile Vulnerability
Help and Support Center Vulnerability
Utility Manager Vulnerability
Windows Management Vulnerability
Local Descriptor Table Vulnerability
H.323 Vulnerability
Virtual DOS Machine Vulnerability
Negotiate SSP Vulnerability
SSL Vulnerability
ASN.1 “Double-Free” Vulnerability
Download the Windows patches for this vulnerability.Here is the link below:
http://www.microsoft.com/technet/security/bulletin/ms04-011.mspx
How Can I Remove the Sasser worm?
Follow these steps in removing the Sasser worm.
1) Disconnect your computer from the local area network or Internet
2) Terminate the running program
Open the Windows Task Manager by either pressing CTRL+ALT+DEL, selecting the Processes tab or selecting Task Manager and then the process tab on WinNT/2000/XP machines.
Locate one of the following programs (depending on variation), click on it and End Task or End Process
avserve.exe
avserve2.exe
skynetave.exe
any process running with the "_up.exe" suffix
Close Task Manager
3) Activate the Windows XP Firewall (if running Windows XP) or another firewall to prevent the worm from shutting your system down while downloading the patches. To activate the Windows XP firewall, follow these steps.
Click on Start, Control Panel
Double-click on Networking and Internet Connections, then click on Network Connnections
Right-click on the connection you use to access the Internet and choose Properties
Click on the Advanced Tab and check the box
"Protect my computer and network by limiting or preventing access to this computer from the Internet"
Click OK and close out of the Network and Control Panel
4) Remove the Registry entries
Click on Start, Run, Regedit
In the left panel go to
HKEY_LOCAL_MACHINE>Software>Microsoft>Windows>Current Version>Run
In the right panel, right-click and delete the following entry
"avserve.exe"="%Windir%\avserve.exe"
"avserve2.exe"="%Windir%\avserve2.exe"
"skynetave.exe"= "%Windows%\skynetave.exe"
Close the Registry Editor
5) Delete the infected files (for Windows ME and XP remember to turn off System Restore before searching for and deleting these files to remove infected backed up files as well)
Click Start, point to Find or Search, and then click Files or Folders.
Make sure that "Look in" is set to (C:\WINDOWS).
In the "Named" or "Search for..." box, type, or copy and paste, the file names:
avserve.exe
avserve2.exe
skynetave.exe
C:\win2.log
Click Find Now or Search Now.
Delete the displayed files.
Empty the Recycle bin
6) Reboot the computer and update your antivirus software, and run a thorough virus scan using your favorite antivirus program.
For Automatic Removal of Sasser, download the Symantec removal tool, you'll still need to download the patches above and install them, however this removal tool will stop the Sasser worm from running, remove the items in the registry, and delete the infected files.
Dec 27, 2009 | Toshiba Portege M400-S5032X Tablet PC
Changed computers and Artista 180 needs Windows 95 to exe the set up program. Also downloaded V3 in 2003 and need to have that running on the new computer. HELP
Windows is able to run applications in Compatibility mode. Open the cd in Explorer, RIGHT click on the setup.exe file you see there. In properties look for compatability mode and set it to windows 95. It doesn't always work but often will.
Jul 17, 2009 | Bernina Artista 180
Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
May 11, 2009 | Microsoft Windows XP Media Center Edition...
Psion Workabout MX Logo
195 people viewed this question
Top Psion Computers & Internet Experts
richie46
ray gallant
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
