Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
No image coming through on my cam
Everything on my camera seems to be working fine except that I cannot capture any images. Basically, the lens no longer views anything. The lcd screen is fine and I can play back the tapes on it. Sound works too but when I switch to capture mode it's as if the camera is "blind".
Just before this happened I noticed that when I was capturing, the image was changing odd colors or becoming fuzzy, and there seemed to be light spots that would appear. Suddenly it went blank and that was the end of it.
  • 4 more comments
  • Daeva May 26, 2008
    What exactly is a CCD Imager and would you know if this part and repair would be costly?
  • Daeva May 28, 2008
    I'm in Canada
    Thank you so much. That' exactly what it is. It's so nice to know that it will be repaired free of charge. I would hae never known. Again, thank you very much for your help.
  • Anonymous Jun 09, 2008
    camera do not capture images
  • Surend51 Jun 15, 2008
    There is no image in view finder and LCD in recording mode. Does not record. Can play tapes.
  • JB1166 Sep 10, 2008
    Hi, I own a DCR-TVR33 and it recently started to have odd colors and then go fuzzy and finally went blank I cannot see anything but still have sound. How can that be fix?
    Thank you, Jessica.
  • 10,594 Answers
Dear Daeva,
CCD Imager of your DCR-TRV33 got defective due to unknown reason. You should go to nearest Sony service shop for replacement of faulty part.
Posted on May 26, 2008
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Was dropped. Now will do everything EXCEPT take photos. Lens, display, flash, etc. etc. all work fine. Just no screen image or photo when in "shoot" mode.
Sounds like the CCD or a stuck shutter blade. Try this place: www.CamerasAndParts.com They only service Canons and they are the only place we recommend for the Canons. It's all they work on and they are about half the price of most shops, plus the work is just excellent through them.
May 15, 2014 | Canon PowerShot SD800 IS / IXUS 850 IS...
Image has lines and pink in colour
This maybe two problems, the pink color hue in the picture and lines from lens shutter problems. Your LCD is still good. You have to replace motherboard and lens.
Feb 07, 2012 | Canon PowerShot A95 Digital Camera
DC280 Kodak Camera- Everything is working fine
Take the batteries out of the camera and let it sit for around an hour. Turn your dial to "set up", then put the batteries back in and turn the camera on, it should ask you to reset the date and time on the LCD. If it doesn't, your camera is essentially dead. Buy a new Panasonic FZ35 if you can afford it. Best All Around Camera I have ever had including the more expensive SLRs.
Mar 18, 2010 | Kodak DC280 Zoom Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Hi, I seem to have a problem with my Finepix Z1 digital camera. When I take a shot it seems to work ok, and the initial review image seems fine as well. But when I go back and review the image on the...
The clue is with the video.
The video function does not use the shutter. Lines on photo's or over exposure is due to the shutter not closing completely over the lens when you take a picture.
It will require cleaning which means opening up your camera and accessing the lens unit
Oct 28, 2009 | Fuji FinePix Z1 Digital Camera
No image in viewfinder
CCD sensor faulty and has to be replaced ( you can playback fine but no image in capture mode ). Manufacturer's agent should repair this fault free of charge as you clerly bought a faulty product.
Aug 28, 2007 | Panasonic PV-GS35 Mini DV Digital...
Canon A520 Everything works, except the button you take pictures with. It wont work.
I need more information about what symptoms you are experiencing. I am going to guess that your shutter is stuck closed. This would cause a blank image to show on the view screen and your captured pictures. The regular icons and text would still display normally. Is this what you are seeing? If not please explain further what is happening and I will respond again with more information. David Millier Advance Camera Repair
Mar 12, 2007 | Canon PowerShot A520 Digital Camera
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
111 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
