Question about Weedeater Gas Powered Hedgetrimmer Ght225le
I have a weedeater model Featherlite 711334 and the gas lines crumbled to nothing. Not sure how the set up was inside the gas tank as to which line goes where and hooked up to what inside the tank.
  • 885 Answers
There are two lines from the tank to the carburator. One picks up gas and fills the prime bulb, the other is a return line. The pickup line should have a filter on the end of it that is in the tank. The other line just dumps back in the tank. Usually the reason these lines deteriorate is because of ethanol in the gas. Make sure you're using ethanol free gas.
Posted on Sep 30, 2010
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Dry rotted tubing on my weedeater blower.
Have it replaced at a lawnmower repair shop.
1.) Have them check the grommet (black round rubber like a thick coin with 2 or 3 holes), replace it if it is crumbly. It holds the fuel line and the fuel vent line - if your trimmer has it. Grommets on the average cost about $6.00. Not all trimmers have fuel grommets, some of them only have holes right on the fuel tank. 2.) Replace the fuel line with Tygon fuel line hose. Tygon can withstand UV light, petroleum, high and low temperatures while retaining its shape. Just make sure the replacement tube is of the the same inside diameter. For a small piece of Tygon hose, ave. cost no greater than $8.00. 3.) Replace the fuel filter. The one inside the tank, connects to the end of the fuel line. Fuel filter, good ones are about $4.00.
Aug 23, 2009 | Garden
WeedEater Featherlite String Trimmer fuel leak.
give it a week to see if the fuel hose swell and stop leak sometimes i have the same problem.
and ill wait for a week and it quits leaking.try that
Jul 30, 2009 | Garden
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
The filter in the gas tank came off.
The filter should only fit in the end of one of the lines (probably the larger diameter one) The smaller line usually goes from the tank to the primer bulb and the larger one goes to the carburator. The filter just sticks in the end of the fuel line.
Jul 01, 2009 | Poulan Featherlite Gas Blower, with Low...
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater Gas Powered Hedgetrimmer Ght225le Logo
1,281 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
