Question about EuroCave Comfort 260 Collector's Package Wine Cellar - Black
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Posted on Oct 15, 2010
  • ranchuk Mar 21, 2011
    Did the filter change work for "majidfateh"? He or she should also be sure that no wine bottles of other contents are touching the back wall. Not only can this lead to ice buildup, but it can also cause the wine and/or cork to be too cold or even freeze. I just purchased an 8-y.o. used Eurocave D-264W (same basic model as his/hers). The seller said it had been in use continuously since new. At the time of purchase, it had a 1-inch thick ice buildup on the back wall, but only within the "chiller" compartment at the bottom. This compartment has a sliding glass door on it and is designed to stay colder than the rest of the unit. Items in this compartment sit on a rack above a plastic pan on the interior floor of the unit, designed to drain via a tube into another pan outside the unit for evaporation of condensate. The seller had it jammed which bottles of champagne, some of which were wrapped in cellophane and many were contacting the back wall and were actually frozen to the ice sheet.
  • davetdunne
    davetdunne May 03, 2012
    Hi Majidfaeth,
    Most causes of ice up is as follows.....
    either the temperatures are too far apart from each other (10oc maximum Europe)
    no carbon filter installed
    faulty thermostat (Can be checked easily).
    DD
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
What number is the lithium battery that operates the display
lithium 357, any brand will work and can be purchased just about anywhere.
Apr 10, 2014 | EuroCave Comfort 260 Collector's Package...
Ice in the unit. Whould shoud I do? Who should I contact to get the service...What kind of filter does it take and where can I purchase it?
I also have problems with ice in my unit. How can this problem be solved? Do it need a repair technician to come out?
Sep 02, 2011 | EuroCave Comfort 260 Collector's Package...
Thermostats are not working; unit is freezing up inside;
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
defrost timer is not working..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | EuroCave Comfort 260 2-Temperature Wine...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Avanti Beverage Cooler BCA5105SG running very loud.
Inside the cooler is the evaporator fan usually right in the middle behind a cover. As it slows down you have less circulation and ice forms quicker and cooling is diminished. Sounds like it is going out.
Sep 14, 2009 | Avanti (BCA5105SG) Beverage Cooler
WATER COMING OUT FROM THE FREEZER SIDE
You most likely have a clogged drain,turn off or unplug the unit Remove the shelves a racks from the bottom half of the freezer section You'll see a metal panel at bottom  at the top of this panel are two screws,remove those and tilt up the plastic panel so you can remove the bottom panel.
 Once that is out of the way you'll see Ice built up in the drain trough at the bottom don't poke around with anything sharp but you can tap the ice with a screw driver handle and break it up for removal,once the ice is removed pour a cup of hot water into the trough to thaw the drain,when it thaws the water will run into the pan under the unit and evaporate
Sep 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
No light, no fans running, nothing. temp gauge still working
It is possible that the unit has a switch somewhere which may have been accidentally switched off? On some units you can switch the complete unit off by turning the thermostat counterclockwise.
Mar 09, 2009 | EuroCave Comfort 260 Collector's Package...
Temp won't go down to target
Sounds like your unit is low on refrigerant gas.  Too little gas causes rapid boiling of refrigerant and makes the cold spots.  You'll need professional help.
Sep 09, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Comfort 260 Collector's Package Wine Cellar - Black Logo
1,436 people viewed this question
Top EuroCave Furniture Experts
Jim London
Jim London
Are you an EuroCave Furniture Expert? Answer questions, earn points and help others
