Question about Kyocera Copystar CS-5035 Copier
I would like to change the name on my scan to PC function on my CS-5035...right now it is set as Angela and I need to change that name to Shannon
  • 113 Answers
Go to internet explorer, type the IP address of the scanner, go to destination list on scan to pc. click your number where your name is appearing. change name and the click registration.
Posted on Nov 29, 2010
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
HOW DO I REPROGRAM ADDRESS BOOK
First I will refer to instructions for the KM-5035 which is the same copier as the CS-5035. The instructions, utilities and manuals are interchangeable.
It depends on what information you are looking to program.
If you want to input Scan to Email - email addresses or scan to PC - addresses directly into the network card so they show up on the copier display you can do it from your computer web browser.
If you put the scanner card IP address into the web browser like yo would enter a website address it will open up the scanner network card and if yo look down the left side of the webpage there are links to take you to the correct page to input the information you need to.
You can also use Kyocera's Scanner Address Editor to load this information. This is a utility that can be downloaded to your computer and then run to input the information. You can download the utility from this link http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11783&rid=17521.
For Fax numbers you can not load them from the web browser but you can load them from Kyocera's Address Editor for Fax. You can download the utility from this link http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11783&rid=17669.
You can also add fax numbers and email addresses from the copier's operation panel
To download manuals go to Kyocera's website at this link http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=11783&pcat=10564&rcid=10009&rscid=10028.
The Scan System Operations Guide covers the use of the utilities.
Let me know if you need more information. Also you can find useful setup information at www.gfbm.net.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Copystar CS-5035 Copier
Ii need to change the number of rings before the fax machine answers on my Copystar CS 5035. How do I do this.
touch the menu button, go to fax default, key in code 6482 and then scroll settings and change the the number of rings
Aug 06, 2010 | Kyocera Copystar CS-5035 Copier
Problem scanning to PC.
Scanner needs:
1- a second ethernet cable and its own IP address.
IP address should be similar to the printer.
2- a folder in PC ie: C:\SCANS. This folder should be input in scanner web page (entered in the address bar of a browser ie 192.168.1.10)
3- Install the file utility resident program in PC.
Feb 05, 2009 | Kyocera Copystar CS-5035 Copier
Touch screen on kyocera 5035 isnt working
Look for a stuck key on the operation panel. Usually is the least used key, a grain of salt will do it!
Jan 27, 2009 | Kyocera Copystar CS-5035 Copier
Non english display cs 5035
Hello sir; Try to return to english first, the procedure as follow;
1, press the keys in order "10871087".
2, enter 018 press "start".
3, you can checksum for the ROM,reset main board, change language.
4, enter "001" press print.
Hopefully can resolve your problem, good luck!
Jan 07, 2009 | Office Equipment & Supplies
Kyocera 6030
you type the ip address of the scanner and then through the web browser you then enter into the address book.General/contacts etc
cheers.
Sep 25, 2007 | Kyocera Copystar CS-5035 Copier
Kyocera Copystar CS-5035 Copier Logo
128 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
