Question about Hampton Bay 56 In. Florentine IV, Brushed Nickel Fan
My Hawkins 44" fan makes a humming noise when the fan is going. The faster the speed the louder the noise. With light on only , no noise. My assumption is it is electrical. Any advice would be welcomed. Thanks, Todd.
  • 490 Answers
Unless it is really loud, the noise you describe is quite normal. Often, at higher speeds the whooshing of the blades will mask some of the motor sounds. we have found the Hunter fans to run the quietest.
Posted on Sep 30, 2010
Why is there wobble and a humming noise at certain speeds?
Usually a humming noise ( will get louder the faster you go ) is associated with a worn/bad wheel bearing. If the bearing is worn bad enough, it can also produce a wobble. Have the bearings checked on the side/wheel the problem is coming from
Jan 15, 2016 | 2003 Pontiac Grand Prix
Pull chain hanup on glass light cover
Take the glass off and see if there is a hole in a small plate below the light sockets. The pull chain should go thru this hole first before the glass. I don't know if this has it or not being that it's a low-end store brand fan.
Jul 28, 2013 | Hampton Bay Ceiling Fan. Hawkins 44 in....
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
I have a 2000 Honda Accord and as I accelerate over 45 mph the care starts making a progressively louder humming/buzzing sound. When I turn slightly to the right the noise will go away. Any ideas wh
sounds like the wheels are out of balance, is there a slight vibration through the steering wheel at this speed? and does the problem stop if you go faster (please drive carefully)
Jan 24, 2012 | 2000 Honda Accord
Transmission hums. faster the speed higher and louder the hum. Almost sounds like super swampers. Wheel bearings for sure not the issue.
If the trans hums, the problem is in the trans and will have to come out for repairs. You say its not the wheel bearings, but thats a real common problem, and also the tires can make noises like a wheel bearing. Have a Professional check it out.
Nov 09, 2009 | 2003 Chrysler PT Cruiser
2004 Chrysler Crossfire 25,000 mls auto, road hum noise
MOST of the hums after a while come from the diff as the back axle does the driving and almost all its life runs the same way except when going in reverse ,is the rear diff meshing and worn on both the crownwheel and the pinion and the humming gets slightly louder the faster you go and almost goes when almost stopped and this can also be the slight vibration you get so get the diff oil drained and refilled and check if there is any metal in the oil when drained if so thats your problem But it will last for years like that..Let me know how you get on RON
Oct 23, 2009 | 2004 Chrysler Crossfire
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Altura 68" ceiling fan noisy
TAKE THE DARN THING BACK, IT SHOULD NOT MAKE ANY NOISE.
Jan 13, 2009 | Hampton Bay 24002 Ceiling Fan
Humming noise from the front end
it also happened to me i had it checked and the local mechanic just changed the fan belt of my car, try to change your fan belt....thanks.
Jun 18, 2008 | 2001 Acura 3.2TL
Hampton Bay 56 In. Florentine IV, Brushed Nickel Fan Logo
555 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
