Question about Kenmore 44102 Front Load Washer
Kenmore front loader in not starting its cycle??
  • Kenmore Master
  • 17,130 Answers
If the first inputs are coming in , the input valve opening , the water flowing into the washer and shutting off when the level is reached due to the water pressure switch, the program controller must now allow the driver to switch the motor.
if these cycles are not happening then the controller must be checked.
Posted on Sep 30, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Posted on Aug 25, 2008
SOURCE: Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Posted on Mar 18, 2009
ICmanServer
  • 129 Answers
SOURCE: kenmore front loader not draining or doing a
Hi...
There are several ways to fix this problem, we need to check first the parts before we do a hard troubleshooting. Check this parts first.
Inspect the drain hose for kinks
Test the timer control
Test the lid switch(some models)
Inspect the water pump
Inspect the driver belt(belt drive only)
Inspect the motor coupler
Those are the parts that we need to check
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Good luck !
ICmanServer
Posted on Aug 01, 2009
SOURCE: My Kenmore Elite front loader HE3 washer will not start.
my fabrc softner dispenser will not drain
Posted on Sep 11, 2009
  • 92 Answers
SOURCE: My Kenmore Front Loader washer machine is making a
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Posted on Jan 11, 2010
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore front loader only runs hot?
you got the pipes hooked up right? XD
also check that the cycle you selected isn't a hot wash cycle.
Nov 17, 2013 | Washing Machines
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
Kenmore front Loader washer leaking from bottom
I want you to run an empty load, pour 3-4 cups of white vinager into the soap dispencer, this will flush out detergent buildup, it sounds like the unit has a buildup of soap and is oversudsing, the vinager wash will stop it from happening, if this stops the problem cut the amount of soap you are using in 1/2. If it does not let me know, good luck
Jun 07, 2010 | Kenmore 43142 Front Load Washer
I have a front loader. When I shut the door and
pin on door switch is brocken. look on top of door latch
Feb 12, 2010 | Kenmore Elite 45986 Front Load Washer
The control panel (touch panel) is faulty - and must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Nov 08, 2008 | Washing Machines
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Kenmore 44102 Front Load Washer Logo
370 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
