Question about Microwave Ovens
Everything else on the microwave is working fine, just not heating the food.
  • Microwave Ovens Master
  • 17,129 Answers
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
check the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Sep 30, 2010
  • 10,865 Answers
Hello. When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician. That said, if your microwave is a counter top model you may be further ahead to replace as opposed to repair. J.
Will not heat
If everything else is working fine, the magnetron is the likely problem, "heats food and is the heart of the microwave oven" if more than five years old cheaper to replace the whole item.
Mar 02, 2012 | Whirlpool Microwave Ovens
GE microwave model JVM1750DM does everything except heat food. Worked this morning fine.
Chances are the magnetron has failed, "heats food" the other possibility is the high voltage capacitor and diode. Repairs will approach the cost of a new microwave oven.
Apr 19, 2011 | GE JVM1750DM Microwave Oven
Food would not heat up. Everything else works fine.
Most likely the problem is a shorted diode or magnetron
Did you change the diode as well, if not you need to change it
Aug 10, 2009 | GE JE1160 Microwave Oven
Microwave wont heat
Check out the door switch. Could be malfunctioning.
Jul 10, 2009 | Maytag MMC5000 Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Nov 22, 2008 | Sharp R-303CW Convection / Microwave Oven
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
