Question about Apple 24" iMac Desktop
How to eject a cd or dvd stuck on a slot driver?
    Brigadier General:
  • 10,406 Answers
Turn the computer off.
Straighten one end of a Norwegian paper-clip, and insert that end into the small hole near the slot.
Push it in until you feel resistance.
Then, push another 6mm (1/4 inch).
The drive should "unlock".
Remove the paper-clip.
Turn the computer on, and it may "eject" the disk.
Posted on Sep 30, 2010
Can't push button to open CD/DVD player - won't open. Help?
What to do if you get a CD or DVD stuck in your computers optical drive, and it won't eject. You can take several steps to troubleshoot stuck DVDs or CDs.
Computers are what they are, complex. Meaning, a stuck DVD could be one of several possible things. Sometimes it may be easy to fix. Sometimes, not so easy. The best thing to do is troubleshoot the problem.
Here is what you should not do:
- Stick a screwdriver, pocket knife, credit card, or any other object into the DVD drive and try to pry it open or pull the disc out. When stuff doesn't work right, I feel like tossing my computer across the room just as much as the next guy. But just don't do it. Troubleshoot first.
Method 1 - Try Ejecting from Within Windows Navigate on over to Start > Computer. Right-click on your CD/DVD drive choose eject from the drop down menu. Sometimes you can eject the stuck disc using Windows commands.
Method 2 - Software and Drivers The CD/DVD drive was working a week ago right? But all of a sudden it just stops. Chances are good, that you may have installed a program, application, update, driver, etc., that messed with the CD/DVD drive driver.
To troubleshoot this, try doing a system restore. A system restore will uninstall several files and changes to your computer that were made within a certain time frame. If you have just recently upgraded your operating system, this often times cause some device drivers incompatibilities.
Another thing that you can try, is uninstalling the driver for your CD/DVD drive, and reinstalling it. To do this, you will need to make sure that you have a backup of your driver. You should be able to download it from your CD/DVD drive manufacturer's website.
Nov 30, 2015 | eMachines E181H 18 inch LCD Monitor
Dvd player
hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
Sep 03, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Tip
How to eject a disk from a slot drive, when you've tried everything else
This is about trying to eject a CD or DVD stuck in a slot drive.
Most computers have a drawer-based cd drive which rarely suffers from disk jams.
Some high end PCs (and nearly all Macs) have slot drives where you feed the disk into a slot, the disk is then pulled into the machine. This gives better structural strength to the case, looks neater etc etc...
The problem is that occasionally a disk will get stuck. and there’s no little release hole on the front to push a paperclip in. There is lots of advice on the internet for the Macs, the Wii, and Pioneer drives of varying types, and most of these advise OS tricks, or firmware commands, however this trick is for when all those methods have been tried, and the disk is still trapped in the machine.
The idea is to stop the disk spinning and fool the drive into thinking the CD is bad, and it will eject it. I was taught this trick by a retired engineer, and it works a treat.
Fold a piece of cardboard (I used the side of a Frosties box) lengthways twice, until it’s quite stiff... Carefully push it into the slot until it bumps up against the edge of the CD/DVD.
Start the machine, and push the cardboard firmly against the disk to prevent it spinning. Wait for the regurgitating noises, and remove the cardboard to allow the disk to be ejected.
Easy.
on Jul 26, 2010 | Computers & Internet
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
Cd drive wont eject
Try ejecting it through "My Computer". Right click on the drive and select "eject". If you can't locate the drive, then it's probably missing the driver.
Nov 25, 2010 | Sony VAIO VGN-NS240E/W Notebook
Where is the CD drive on the Dell studio laptop need to put in disc for printer
you can see a slot on the right side of the laptop. you need to put cd in to that. you cannot see any CD Drive coming out of this model. Its a slot CD/DVD reader. So jst push the CD in to the slot. it will start palying. to eject go to my computer and right click on CD driver and click on eject. thats it ok
Jan 19, 2010 | Dell Studio 15 Laptop
Dell xps desktop slot load optical disk drive stuck. Wont eject disk and no pin hole to stick a paperclip in.
It's probably a driver issue, I know this because I reinstalled WIN7 Pro, because of some experimenting and it was after the reinstall that media wouldn't eject using the touch-bar ejecter, although I was able to get everything else working flawlessly. No problem though, just open My Computer, right click on the CD/DVD Drive and click eject from the pulldown menu. Currently I'm looking for the driver fix, but haven't found it YET~! P.S. Anyone who thinks or says it's the BIOS is crazy... don't listen to them. It's more than likely a chipset driver because it's hardware, but don't rule proprietary software. Hope this helps~!
Dec 21, 2009 | Dell (0F146) Internal DVD Drive
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
CD STUCK IN THE THE DVDRW DRIVER
Is it that the cd drawer will not open? If so-go to my computer and rightclick on the cd drive and select eject.
Jun 11, 2009 | Dell INSPIRON 6000 CENTRINO...
Apple 24" iMac Desktop Logo
200 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
