Question about Mitel 5303 Conference (50001905)
MITEL 5303 Conference Phone question: during connection of a few numbers and 1 number is busy - how do you drop that call without dropping all parties connected?
    Sergeant:
  • 378 Answers
I believe that if you reach a busy signal, you can hang up. The conference should ring you back and the rest of the conference will be there.
Here's what the documentation shows from within the help of a 3300 ICP/MCD...
a 5303 is to be treated just like a 2500 series set...
2500, 5302 IP Phone, SUPERSET 401, SUPERSET 401+, and SUPERSET 4001 telephones:
To form a Conference when a two-party call is already in place, or to add another party to an existing Conference:
  1. Press Flash or flash the switchhook.
  2. Dial the number of the next party.
  3. Wait for an answer.
  4. Press Flash or Flash the switchhook.
  5. Dial the Conference Call Feature Access Code.
To Leave a Conference:
  • Hang up.
2500 telephone:
To split a Conference and speak privately with the original party:
  1. Flash the switchhook.
  2. Dial the Conference Call Split Feature Access code.
Posted on Apr 22, 2011
How do you input numbers during a call, example you call and want to enter a 1 for customer service or and extension number. I entered the numbers but nothing happens.
these are your options: while on call, select the number you wish to call from your phonebook, touch the contact on the screen, then press send. To switch between calls, press send key (the picture of the phone), touch and select swap calls.
the second option is to make conference calls, the number of persons in the conference call is 5. But this is network dependent. (check with your provider if they support this service). You can do this, by entering the number you wish to call or from your phonebook. Then press the send key (logo of the phone down). When the second call is connected, the first call is automatically put on hold. You can swap between calls by pressing the send key. To join the calls, touch the notepad logo, then select join calls sub option from the conference call menu.
Apr 23, 2011 | LG Xenon GR500 Cell Phone
Is there a way to block a specific phone number on Mitel Superset 4025?
Normally no. Your phone is part of a business telephone system. The system allows the sharing of incoming/outgoing telephone lines. If you need a specific phone number blocked, it will have to be blocked on these in/out lines. Unfortunately such lines are considered business class lines and you normally cannot block a specific number from calling you.
If you have trouble with a specific number, I believe you will have to contact the police before your carrier will be able to provide a block.
Apr 12, 2011 | Mitel Superset 4025 Corded Phone...
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
Mitel 5310 not powering on
What phone do you have it connected to? Some phones will allow the PoE to pass onto the 5310, others require a 24VDC power cord.
Feb 04, 2010 | Mitel 5310 Audio Conference
Invalid Set Type Check CDE
The original setup of the phone was most likely done on a mitel 5224, you can only use this model or newer. The 5220 or 5215 will give this error when trying to replace the original phone. To use these phones, delete the extension and redo it.
Jul 12, 2009 | Mitel 5303 Conference (50001905)
How do I put my Mitel Superset 4015 on speaker phone during a call?
Sorry to tell you, but the Superset 4015 is not capable of doing this conference feature.
It has loud speaker capabililties (for paging, or listening to calls), but no microphone for your conference meeting.
Apr 10, 2009 | Mitel Superset 4015 Corded Phone
We have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Apr 02, 2009 | Mitel 5212 IP Phone
MITEL 5303 Conf Ph
These are analog only phones using a POTs line if you've connected everything properly and all the cables are in fine condition no broken conductors or anything it should work. If the keypad lights up you only need to hit the very buttom button and you should get a dialtone. To make a call you may need to dial a 9 or 909 (depending on the phone system programming) to get an outside line if this connected on an anolog line through a PBX. Probably first test it using a working faxline. If you do not get a dialtone and all cabling looks good it maybe that keypad got dropped. I have one that has been knocked off of a table - someone tripped over the cord - noone will admit it but through testing I've discovered it's in the keypad end, symptons being no dialtone.
Jan 28, 2009 | Mitel 5303 Conference (50001905)
Need ''short'' cord pinout for Mitel 5303
I have made these cords up before, this cord only uses 2 conductors so a length of Cat3 (station wire) 3 pair or less would be more than enough. Looking straight at the jack end with the tab facing down the pins are numbered from right to left, starting at 1 from the right to 4 or 8 depending on whether it is RJ11 or RJ45. On the RJ11 end pin 2 is red and pin 3 is white,on the RJ45 end pin 1 is red and pin 2 is white. That's it all you need is a crimper and the ends.
Nov 24, 2008 | Mitel 5303 Conference (50001905)
Wanted to use two mitel 5303 for one conference call
Yes you would have to have them on seperate analog phone lines and 1 would have to dial the other. To add a 3rd party you have hit the flash button dial the other party, connect, and hit flash again.
Mar 19, 2008 | Mitel 5303 Conference (50001905)
Mitel 5303 Conference (50001905) Logo
354 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
