Question about RTO Ho Herpa Freightliner Truck Tractor
Freightliner trouble codes for electrical truck. Trouble code ECU 128. When engaging master and pto switch the check engine light comes on. At random times with this light on, we loose throttle control of the foot pedals which operate terex boom with man bucket. Then also the odd time after dissengaging master and pto switch and putting truck into drive position, we loose throttle control right at the steering wheel while driving. When this happens a check engine light and code ECU 128 appears on dashboard.
3 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: steering wheel removal instructions for 2005
you will need a specel tool so you will not cut your horn wire that comes up through the shaft,I made mine and the bolts that go in the steering wheel to pull it off are metric,if you need a pitchure of it I will email it to you,wilsodfarm@yahoo.com
Posted on Jul 30, 2009
  • 28 Answers
SOURCE: fix revers in automatic Freightliner Truck
Which transmission you got. Zf meritor or ultrashift?
Posted on Dec 11, 2011
C1422 what is this code mean c 1201
Error Code: C1201.
Description: Engine Control System Malfunction.
Trouble area:
- Inspect engine control system.
- Wiring.
- ECM.
Error Code C1422.
Description: Master Cylinder Pressure Sensor Zero Point High Malfunction.
Trouble area:
- Stop light switch Stop light switch circuit
- Master cylinder pressure sensor circuit
- Brake actuator assembly (Master cylinder pressure
sensor).
Jun 01, 2015 | 2010 Toyota Corolla
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
Check engine light stays on. changed oxygen sensor, pcv valve, coolant sensor, switched out PROM chip, and cannot get a code to blink. replaced all hoses coming off carb. smog pump and egr valve been...
what you could start with is checking to see what trouble codes are being logged for this vehicle...if the engine light stays on, it means the ecu is registering a fault......by the means of a trouble code...now the trouble code doesnt tell you how to fix it, but it does give you the direction to go down...judst wondering if you have tried to obtain the trouble codes
Aug 26, 2010 | 1981 Chevrolet Corvette
HAve a 1999 sonata the car when we accelerate car has a loss of power also the check engine light goes on with code p1520. what could it be
There is NO SUCH CODE as P1520... However, there is a Code as P1529 - TCM MIL request to ECM This is a transmission trouble code.
Whenever the 'CHECK ENGINE' light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE and perhaps eventually fix the problem.
Oct 28, 2009 | Hyundai Sonata Cars & Trucks
Check engine light and esc light comes on no driving power
Replace the brake/stop lamp switch at the brake pedal, also check for trouble codes. Whenever the 'CHECK ENGINE' light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any codes which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE and perhaps eventually fix the problem.
Oct 14, 2009 | 2006 Hyundai Sonata
Check engine light
Oct 06, 2009 | 2000 Hyundai Accent
Temperature gauge not working
Yep!... take it back to the mechanic and tell him/her to recheck the system (there's no such DTC (Diagnostic Trouble Code) as "bad electrical connection"... somebody's pulling your leg!
Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on.
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code(s) which may have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
Oct 03, 2009 | 2004 Hyundai Elantra
Air flow meter problem, the car jerks and switches off when i slow down or release acceletar
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
Sep 30, 2009 | 2002 Hyundai Accent
2000 hyundai elantra car cranks but wont turn over just started fine 3 days ago
Did you scan for any trouble codes? Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps fix the problem.
Sep 10, 2009 | 2000 Hyundai Elantra
Eng turns strong, 2007 Freightliner Columbia 60 series Detroit
YOUR PROBLEM MAY NOT BE THE FUSE TO THE E.C.U. TRY THIS. 1. TURN ON THE KEY AND LOOK FOR THE CHECK ENGINE LIGHT (USUALLY YELLOW) AND THE STOP ENGINE LIGHT (USUALLY RED) WHEN YOU FIRST TURN ON THE KEY THEY SHOULD COME ON. AFTER ABOUT 5 SECONDS OR SO THEY SHOULD GO OFF. WAIT!!!!! ANOTHER 5 SECONDS AND SEE IF THEY COME ON. IF NOT TRY STARTING THE ENGINE.
IF THESE LIGHTS DO NOT COME ON WHEN YOU TURN ON THE KEY THEN CHECK THE WIRE THAT LEADS FROM THE POSITIVE SIDE OF ONE OF THE BATTERIES AND CONNECTS TO THE ECU.
IF THIS IS LOOSE IT WILL CAUSE THIS PROBLEM. THERE ALSO MAY BE AN INLINE FUSE ON THIS WIRE TO PROTECT THE ECU CHECK THE FUSE.
IF THE LIGHTS WENT OFF AND CAME BACK ON THEN YOUR ECU IS SHOWING A FAULT CODE. WITH THE ENGINE OFF AND THE KEY ON, PUSH THE ENGINE OVERRIDE BUTTON AND TAKE A PEN AND PAPER AND WRITE DOWN THE FAULT CODES. THE WAY YOU GET THE CODES IS BY WATCHING AND COUNTING THE NUMBER OF FLASHES OF THE YELLOW LIGHT AND THE RED LIGHT. FOR INSTANCE IF THE YELLOW FLASHES 5 TIMES AND THE RED FLASHES 3 THEN YOURE GETTING FAULT CODE 53. FIND YOUR CODE AND CALL THE SERVICE DEPOT AT THE DEALER AND FIND OUT THE DEFINITION OF THIS CODE.
LAST BUT NOT LEAST CHECK THE COOLANT AND ENGINE OIL BECAUSE THESE TWO THINGS WILL SHUT DOWN AN ELECTRONIC ENGINE FASTER THAN ANYTHING. ESPECIALLY IF A SENSOR HAS GONE BAD SUCH AS COOLANT LEVEL SENSOR OR OIL PRESSURE SENSOR. MY EMAIL IS JAMESFWALKERJR2006@YAHOO.COM HOPE I WAS ABLE TO POINT YOU IN THE RIGHT DIRECTION IF YOU HAVENT ALREADY SOLVED YOUR PROBLEM.
Apr 29, 2009 | Walthers Ho-athearn-5506-freightliner...
RTO Ho Herpa Freightliner Truck Tractor Logo
3,350 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
