Question about Bush Televison & Video
BUSH 32'' LCD AT FAULT
Flashing Standby LED No StartUp.
  • 1 more comment
  • enrmas May 25, 2008
    Thanks Jerry.
    I am definitely not an expert but I can use a soldering iron and a tester.
    You referred to board swapping which doesn't tell me too much.
    If you explain me precisely what I have to do I can give a try and give you further information.
    Cheers
  • enrmas May 26, 2008
    Jerry
    Thanks a lot. Now it's a lot clearer.
    Anybody who could do that in my area (UK, postcode KT11...) for a reasonable price?
    Cheers
    Thanks once more Jerry
    Genius:
  • Bush Master
  • 1,689 Answers
Most of the time, this is from a failed power supply board, and or a short on one of the other boards. Without board swapping this is a difficult thing to troubleshoot.
Jerry G.
Posted on May 25, 2008
  • Jerry Greenberg
    Jerry Greenberg May 26, 2008
    There is no actual support by the manufactures for component level service in these sets. Even if I had a detailed service manual, I would not be able to determine the failed components unless I was to spend many hours troubleshooting the set using the proper diagnostics and instruntation. This would not be feasable by any means in comparision to exchanging complete boards. The circuit designs are extremely complex, and the are thousands of SMD type compenents involved.
    For soldering, you cannot go in with a standard soldering iron and change parts. The micro size SMD parts are changed using IR soldering systems that are very costly. Some of the pin spacings on some of the devices are closer than 1/50 of an inch apart and almost as find as a human hair.
    If you were able to determine the defective part, if the the part is not a generic type that can be bought at a regular electronics parts supplier, you would not be able to buy it from the manufacture since they do not support component level service. In many instances the specialized IC's require some software loading and parameter adjustment to adjust to the particular set.
    This is why the service reps are given boards for exchange from the manufacture. It is the same method as for servicing a computer but more involved.
    With board exchange, the set can usually be serviced within thirty minutes to one hour including calibration setups, unless there are some problems with the wiring harnesses, or something unexpected.
    Jerry G.
  • Jerry Greenberg
    You have to find out in your area who the authorized service people are for the TV manufacture. In the user instruction manual there are usually listings. I tried to find Bush using Google and Yahoo and came up with nothing in the way of support. You can ask the dealer where you bought the set.
    I have a feeling that this set may be a re-badged no-name brand set. There may not be any service support at all from what I can see. Here in Canada I have never seen this brand name.
    The corner service shops who are usualy independent, may not be able to have the spare boards for your set, or they may have to buy them to try them if they can source them. This will be more expensive than using the factory authorized service rep.
    I can tell you in advance that the boards for these TV sets are very expensive. In many cases it is actualy cheaper to replace the set rather than to service it.
    When you replace this TV set, make sure you buy a set that has local support and service. Stay with the big name brands that are well known. You may pay a little more, but it is worth the investment.
    Jerry G.
Power supply fault?
Check all electrolitic capacitors at power supply area : better replace them.
Apr 15, 2008 | Bush 2871NTX 28" TV
How do i fix a bush tv? it just flashes from standby comes on for 2 sec then off and the standby led starts flashing again .
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 09, 2016 | Bush Televison & Video
I have a bush tv its got sound but no picture
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Apr 08, 2015 | Bush Televison & Video
LG flatron l1915s monitor, green led flashing only when coming out of standby resulting in no picture
Check the electrolytic capacitors inside in the power supply board portion. replace all busted ones.
Jan 10, 2014 | LG L1915S 19" LCD Monitor
Bush led 26916hd
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Bush LCD/ Plasma/ LED Pivot Mount in Black
Hi! I have a 32" LCD led backlit bush tv (not sure
Yes, all the issues point to a problem in the standby power supply which runs 7/24 if the set is plugged into wall power--get it taken care of under warranty before it really fails bad.
Dec 17, 2012 | Televison & Video
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
My Sony Bravia KDL 32S2030 is showing a flashing led standby (4 flashes/2 secs/4 flashes. I can unplug the mains cable, leave it for a few minutes and when I pug it back in it will re-set to the green...
I'm not a service tech, but, I do have a copy of the service manual. It says the TV has a self diagnostics and according to the chart, 4 flashes indicates a backlight failure.
Oct 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
Televison & Video Logo
254 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
