Question about Maytag Dryers
Maytag dependable care plus , Heavy Duty 6 cycle electric dryer, electronic dry control, no clue as to the year model, model # LDE 9824ACL. Installed duct installation, plugged cord in, an electrical spark ignited on the area connecting duct to dryer, now...nothing, it is completely dead. I bought it used from a stranger who said that it does work well except for being a little louder than normal, and shouldn't be hard to get adjusted. I was gullible and bought it without testing it out and knowing nothing about the mechanics of washers or dryers.
4 Suggested Answers
  • 1073 Answers
SOURCE: I have a Maytag Dependable
what is the model number
Posted on May 05, 2008
  • 205 Answers
SOURCE: Maytag Dependable Care Plus/Heavy Duty
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Posted on Sep 24, 2010
rein16502666
  • 31 Answers
Must replace it cause there is a flat side on the shaft and the blower wheel matches up to it and rounded out the plastic. Take off front panel and take out the screws around the wheel to get the metal plate out of the way then it either screws on or has a snap ring and a clamp to take off now wiggle the wheel to slide it off. Install new wheel and put back together.
Posted on May 02, 2011
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
Instructions
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
Maytag Dependable Care Plus/Heavy Duty Dryer Model # LDG9304AAM Dryer is turning, there is heat but clothes are not drying
Sep 24, 2010 | Maytag Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
I have a Maytag Dependable Care Plus/Heavy Duty, Electronic Dry Control Electric Dryer. It is making a loud squealing thumping noise. I wondered if you might be able to tell me what the problem is and if...
I have the same problem. A wheel on which the drum rests became loose and started wearing enevenly. Replace the wheel - it is very easy
May 05, 2008 | Dryers
Dryers Logo
264 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
