Question about Epson PowerLite 77c Projector
Epson Powerlite 77c constant overheating message. Fan filter is clean, it's also running at low power to lamp. Any suggestions
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 32 Answers
SOURCE: Epson Powerlite 7300 Display Problem
Optical engine failure. Bad prizm.
Posted on Feb 13, 2008
  • 105 Answers
SOURCE: Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Posted on Jun 04, 2009
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
Soulvisitor
  • 1113 Answers
SOURCE: Epson Powerlite 82c over temperature sensor shut down projector. Filter & interior blown out but it still won't light up lamp - confirmed good bulb. Any suggestions? Is there a hardware reset button s
MP82, OPTICAL ENGINE <>>1431299
Discontinued (no longer available)
red_dot.gif 0120 1439509 EMPS4, CASE, LOWER <<> 1412071
Discontinued (no longer available) red_dot.gif 0140 1451875 EMP1715, FRAME,AIR FILTER <<> 1243486 red_dot.gif 0150 1434913 EMPS4, AIR FILTER;A<>>1454798
Discontinued (no longer available) red_dot.gif 0150 1454798 EMPS4, AIR FILTER;A<<>1434913 $ green_dot.gif
9 0251 2118172 EMP1815, FAN, INTAKE;B <>>2119429
Copy and paste from dealer info (with some parts deleted) and Example of Ballast,
Id say the ballast is blown or its power supply (PSU), Sorry I'm not confortable giving you testing procedures for the power supply or ballast as it involves very high voltage, even present when unit is powered down, and is too much of a safety risk to be operated on outside of the workshop without proper systems in place. (ie we are all trained in procedures, and use current limiting devices on our work benches), these things can pack a punch and are not something to be playing inside of. 11_2_2011_8_34_03_am.jpg
Posted on Nov 02, 2011
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
Projector gave a message that it was overheating and then shutoff
chek if all fan are running. check if any extrange thing is in the grids. anyway is better to take it to service.
Apr 20, 2010 | Epson - PowerLite S1+ Multimedia Projector
Epson 77c Projectors occasionally freeze - controls don't work
this is maybe overheating problem, check that the fan on it is working
Fosg2000, please Rate me
Mar 16, 2010 | Epson PowerLite 77c Projector
Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
Feb 21, 2009 | Epson (V13H010L34) Projector Lamp for...
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Epson PowerLite 77c Projector Logo
606 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
