Convergence problem on zenith R50W47. Anyone have a service manual for this?
  • 19,396 Answers
Hi.
I uploaded the service manual at the link below:
Please Click here to start download.. File is the service manual in PDF format.
Good luck.
Ginko.
Posted on Sep 30, 2010
R50w47 no audio no video
Look for resistors or fuse devices associated to the convergence circuit--if one of the chips shorted it will open a part--set detects no voltage and shuts down automatically.
May 16, 2012 | Televison & Video
R56w36 convergence problem. color misaligned. Ghosts.
Dear Sir:
Thank you for contacting fixya.
Please follow the steps below.
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 10, 2008 | Zenith Televison & Video
Convergence was bad. Before kit was used no audio or video
It says Zenith here and if different let me know----if the convergence failed and took a resistor or fuse device (not a glass fuse) out the set will be dead--set detects no voltage to that area and shuts down for protection.
May 16, 2012 | Zenith R50W47 50" Rear Projection HDTV
I have a R50W47C with no sound ...what did happen ??
The audio processor is locked up, unplug the set from the wall for 40Min , and it will reset back to normal.
Mar 07, 2011 | Zenith R50W47 50" Rear Projection HDTV
Colors are misaligned on my zeneth r50w46 and the auto convergence option did not solve the problem. the red droops off on the left side of the screen and the green droops across the top center.
Your convergence IC's are out and this is why you can't use the auto or manual convergence. This type of repair done at a verified Zenith service shop most likely will run you $400.00 to $500.00 dollars. However, if you have some electronic skills and are familiar with soldering and de-soldering, you can do the repair yourself for around $85.00 to $100.00. You will need to buy a convergence repair kit which has all the parts you need and gives pretty straight forward instructions. Plus, if you run into trouble, they have online support. Here is the link for the convergence kit.
http://servicemanuals.vstore.ca/product_info.php/pName/zenith-r50w46-r57w46-convergence-repair-kit
This is not really a hard task to do. It usually takes about 2 to 3 hours from start to finish if you take your time and make sure you follow the instructions to the letter.
Again, if you don't have any sort of electronic skills, it is always better to have the unit serviced by a professional.
Apr 14, 2010 | Zenith R50W46 50" Rear Projection...
Convergence chips and resistors
In order to assist further, more information is required. You indicate that there are some discolored resistors on the board. There should be a marking on the board at each location like: Rxxx Where the xxx is a number. If you can post the numbers here for the parts that are discolored, I can look them up in the service manual for you.
Thanks,
Dan
May 21, 2009 | Zenith R40W46 40" Rear Projection...
Zenith IQD61w20/35 convergence problem
Goto www.TvRepairKits.com - they are experts in this model. There are a few key steps that have to be done during the repair - if not - it will not work.
Apr 19, 2009 | Zenith R57W46 57" Rear Projection...
Adjust Convergence on Zenith B27A11Z
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Feb 09, 2009 | Zenith B27A11Z 27" TV
Zenith converg.serv. menu code: G-Z Chas. with 9-1690
Try this proceedure it should work. Press and hold menu on the set. Then press vol Dn or up plus channel dn so all three buttons on set are pressed down on the set.
May 17, 2008 | Zenith R49W36 49" Rear Projection HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
